136 -
3
Everything posted by k2z3k0
hi Tk thank you for considering this idea "Auto" Channel is exact idea kind regards Kazik
hello again Idea for option in LIVE REC MODE or maybe any REC MODE , that listen to incoming data from recording port and checks channel number changes and immediately is selecting track accordingly on MbSeq So if during recording i move encoder of midi channel #1 it will select Track #1 on MbSeq Also after channel number change he waits (some number of steps for example) and then if channel number is changed then change it,this is to protect from short switches between channels which can cause undesired effects. i think this little feature can improve live recording during the performance kinda "multitrack" recording thanks for your time Kazik
hello everybody just testing new release and about MIDI MIXER CC to BUS is it possible now from MIDI MIXER to change for example Track #1 Semi Transpose(CC48)? just like with New parameter layer "Ctrl"? thanks in advance Kazik
this is xmas again??!! XD thank you Thorsten
dear Midi Maniacs just little idea in FX Panel one page with ECHO on/off (toggle or momentary) as buttons and lets say ECHO time or repeats as potis for each channel hope you like it bests Kazik
hello everyone testing new release ,all works great! two suggestions: could DIVIDER be on a separate button?for example like MIXER. and could SOLO function mute also all other LFO's? kind regards Kaz
hi Thorsten thank you for time and looking into it and if others decide is good enough than it would be great! considering MMC im sory i meant START/STOP could START/STOP be separately ON/OFF thank you kind regards Kazik
hi Everybody during some time now spend with my seq4 ,few times i got in situation when for example track 1 LFO was controlling cc21(filter cut off), and time it took to me to figure out "why is my damn filter cut off on track 1 is moving!?" and it made me think that it could be great to have some indication of it ,preferably in EDIT page now looking on the lcd screens they already pretty packed with vital informations so my proposal is in EDIT page, instead of CATEGORY ,to use 8 lcd characters (counting from top most rightside of right screen) this way there is still one space from NOTE LENGTH to indicate for example,ECHO(ON/OFF),HUMANIZER(ON if one of parameter is different then 0(note,vel/cc,length)),ROBO(ON/OFF), LIMITER(if Lower/Upper is different than 0),LFO(ON if wave type is different then 0),DUPLICATE(ON/OFF),MORPH(ON/OFF),SHUFFLE STYLE(ON if style different then 0) my idea was to indicate with lower (if OFF),and upper(if ON) cases of first letters of each effect ,ECHO=E,e ,Humanizer=H,h and so on i feel this can save a lot of time running around here little example letters are not exactly in place,but just to visualise thanks for your time bests.k
hi everyone a quick proposal here ON\OFF for MIDI MMC messages per port? maybe in BPM menu? for example some synths have sequencer without MMC filter and in result when you hit play on Midibox, synth sequencer also starts this might be undesired situation. thank you for great work TK. bests.k
hi there thank you for response yes bookmarks are ok , just wonder how to assign Divider to one of wilba buttons it is possible to assing other menus like Direction,Fx, and others but NOT Divider bests
hi everybody can Track Divider menu can be assigned to dedicated button? i checked mbseq_hw.v4 file and no option over there. please help bests
hi everyone thanks TK,nice one also i found something: UNDO is not undoing FX:ECHO parameters bests.k
i'll be damned-it works! perfekt thank you very much bests
ok i get it thank you and incoming data is going to midibox to port USB1? thanks
does it matter which micro port?
good lord that is easy i try it right away thank you
hello people is this subject still going on? is this works with mbseq v4? if yes could be there an option for midi data from midi controller goes directly to midibox ? thanks in advance
hi everybody i am trying to remotely select track using given informations via http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fsequencers%2Fmidibox_seq_v4%2Fdoc%2Fmbseqv4_remote_functions.txt&peg=2562 and using Midi Remote cc or note,but can't make it work do i have to press&hold Remote CC&Note and then desired Note that represents function? in Midi Menu under Ext.Ctrl there is no Track selection but for example Play/Pause it is working best regards Kazik
hi people little proposal here could channel have also port and channel number layer!? this way,you can realy play with busses just discovered morping function it is wonderful feature thank you bests
works great.thank you b.t.w. is there way to remotely change select track via incoming midi(cc,pgch)? kind regards
yes that is exactly idea in my mind it could make improvement for live performance bests.k
hi everyone want to share with my idea for a tool ,kinda groovelizer which would modify inside midibox tracks layers, essentialy in my mind it could be simply one of the Track Type's so you have to sacrifice one of midibox tracks or maybe seperate module? ok so my basic idea is- Groovelizer Track Type(or module) would have one Groove sequence(or more), would be great if it could keep regular track functions :Random Generator,Track Length,and Track Divider etc. would be great if other Edit functions work too here and each step of that sequence would be applied to each of the Groovelizer Layers Groovelizer Track Type would have (for example) 8 Layers each Layer contain Parameters: -destination track nr -destination track layer -value range(value(from Groove sequence) div (select divider 1,2,3,4 etc.)) -Value mode:replace,replace inverse,add,sub (decides how value from Groove sequence is appplied to track layer value) Main (EDIT)screen: first row -Groove sequence second row-(selectable) Layer Parameter(track nr,track layer,value range,value mode) maybe it would be possible to have On/Off switch(encoder push), when it goes ON,it makes snapshot of each(8) Groovelizer Layer currently set destination track layer's when it goes OFF,it recals it them of course would be nice to have also option to save current setting(Groove sequence,layer's params),maybe few slots for saving,maybe recall option too please let me know what you think bests K
also it could be sent after pressing STOP(optionaly of course)
hi Everybody short idea would it be usefull option among track settings that you can turn off or on,for midibox to send Note Off message when you Mute or Solo? this way if you have for example longer sample(drumloop) on particular channel that you muting, this sample will be stoped by sampler,very handy otherwise sample is still going after muting it,which could be not desired effect and the same way Solo that will send Note off to every track that have this option on i think this could nicely make mix clean bests k
