136 -
3
Everything posted by k2z3k0
hi there is that wierd that my stfm32f4 cpu is 80% when sequencer is idle and 20% when busy? bests,K
on my mb STM32F4 it doesnt crash(so far) but it does it kinda slow slugish kaz
got it thanks for time bests
Hi Thorsten understood thanks for adding it to whishlist and what about implementing only function that can be turn on or off that would change CURRENT track by listening channel from selected midi in? bests K
Hi Flavio Yes this function works flowles already To make myself clear, Lets say i have track 1 to 8 on mbseq,and this track are on channels 1 to 8 accordingly Now Lets say my master controller have 8 knobs each sends pitch bend to channels 1 to 8 Now if i want record pitchbend for each channel 1 to 8 I need to record track by track changing curent edited track, and i can use only one knob So i thought could it be possible that if i can hit REC And then having 8 knobs adressed 1 to 8 ,depending from what knob i turn Mbseq will record it to track that is adressed to according midi channel Basicaly if im in REC and send pitchbend on channel 3 I would like mbseq to record it to track adressed to channel 3 No matter which track is selected As for now doesnt matter what channel incoming data come from It will be recorded on currently selected track only Other idea was function you can turn on/off that is checking Incoming midi channel and it will select current track according It could work in REC as well as on EDIT mode Sory i went a bit long,just wanna be sure you get me While working with REC mode i felt that could be a huge step towards improving live performing flow So that plus pattern copy(thank you Thorsten) Would open up work flow greatly in my mind Thank you Let me know what you think Bests K
hi there i suppose first option is easier selecting current track in mbseq by checking incoming midi data actualy now thinking about it it could be very handful not only for recording but also just for editing ,example: turning knob lets say for Pitch Bend,Channel 1 on my external midi controller switches current track on mbseq accordingly and thus i do not have to do it myself every time,and when moving my attention to mbseq current track is same as channel of last edited incoming data bests K
hi Everybody did anyone brought up idea of incoming data is recorded(directed) to the tracks that are set to same midi channels that is originaly coming from? basicaly mutlitrack(multichannel) recording? my idea is option that listen to one selected IN port and accordingly to current incoming midi channel it selects current track for recording on the mbseq with the same midi channel set or other way it record(direct) data to track on mbseq with out changing selected track best regards Kazik
Thank you so much Thorsten! Totaly understand mixer map thingy Kind regards Kazik
hello Thorsten pre2 works great! last thing if possible,could COPY,PASTE also copy and paste mixer map? thank you K
Thank you gonna check and let you know kind regards Kazik
im sory i just noticed now that if you do for example ALL on ,COPY,change pattern,PASTE from A1 to A2 so you are on A2 then if you change from A2 to A1 and then back to A2 it will leave on A2 tracks 1,5,9,13 permanent in other words look like doing COPY,PASTE to another pattern(not COPY + PASTE) is permanently leaving tracks 1,5,9,13 first tracks of each group this is happening with version 094 pre1 will test pre2 soon i finished work i hope i made my self clear enough thank you kind regards K
yes i have 3 ideas here when i do COPY+PASTE it permanently duplicates when i do COPY change pattern and then PASTE results will be gone after pattern change so i have to save them i think COPY+PASTE should not do this permanently,i mean after duplication you still need to save results,this way you can experiment and not accidentally overwrite something but thats my idea maybe its something to discuss COPY ,change pattern ,PASTE seems do not including mixer map ,would be great if it does CLEAR button could clear all pattern anyway already works flowles thank you for your time Thorsten kind regards K
hi All would it be possible to have COPY + PASTE in PATTERN MODE to duplicate selected and/or all tracks plus mixer map to the next pattern position,and automaticaly jump to that pattern position,example g1:a1 g2:a1 g3:a1 g4:a1 to g1:a2 g2:a2 g3:a2 g4:a2 this could allow for continues workflow without exporting-changing pattern(means possibly empty so no sound for a moment)-importing it could have also for example option on/off for letting duplication continue from A to B this way you can in no time build a lot of patterns best regards Kazik
one more little thing is there posibility to set DUMP for mixer pages when starting sequencer? kind regards K
hello everyone quick question here is there chance for a Global Transpose function which i could control via loopback Bus i tried remote transpose with duplicate function but didn't worked bests k
hi there im using using v4.092 and when SAVE ALL looks like it doesnt save MIDI -> Transposer And Arpegiator -> Bus,Port and Channel settings kind regards K
here good example of nicely tuned DIRECTION parameters ;)
https://soundcloud.com/mazikandmazik/new-bat008
Hello there Could anyone confirm his Song mode working correctly? my seq is playing next song positions but it does not changing patterns example a1-g1:g1:g1:g1 a2-g2:g2:g2:g2 a3 jump a1 so it will play over and over a1,a2,a3 but it will not change patterns and it will show asterisks g1*:g1*:g1*g1 best regards K
Hello TK thanks a lot for your time to check this out so fast all is working correct now im keeping testing kind regards K
Hello TK looks like now is not hanging,but is not sync also kind regards K
hello everybody short here just testing midibox_seq_v4_092_pre5.zip ,and is it normal that after i turn OFF Pattern Change Synchronisation, then my MidiboX hangs after i wanna change pattern? bests Kazik
