Dimduj
26 -
Dimduj last won the day on June 26 2019
Dimduj had the most liked content!
Recent Profile Visitors
Dimduj's Achievements
2
Subscribing ;) Amazing project ! Keep going and thx for sharing !
The HAARP, a Hardware Advanced Arpeggiator.
Dimduj replied to Antichambre's topic in MIDIbox User Projects
Hi Bruno, Any updates about the haarp project ? Regards, DImitri -
Dimduj started following midiphy SEQ v4+ , MidiBox DAW Controller , Sharing: Adding capacitive touchsensor to midiBox and 5 others
Yep, thx for the explanation I thought the trimpot was a kind of offset not a coefficient. my mistake was trying to set up the trimpot while I’ve values already defined for step 1v, 2v ,... once I setup all the value to zero again calibration was easy and now I got acceptable value for every channel. is got a precision with 15-20 cent variation between octaves of a channel. Do you achieve more precise values on your side ? thx for the support
- 135 replies
- line driver
- cv/gate
(and 2 more)
Tagged with:
Hi everybody, I’ve finished my aout and everything seems to work as expected until I do calibration procedure: i begin with the 5v step at 0v using the trimpot . after that I do 1v, 2v, 3v, 4v steps and when I go back to the 5v step ( with zero calibration correction) the voltage isn’t a 0v anymore.... no matter how many I try to reproduce thoses step. I cannot have a précise calibration and my vcos aren’t tracking properly. ( I use bipolar calibration) any help will be appreciated :)
- 135 replies
- line driver
- cv/gate
(and 2 more)
Tagged with:
Before touching your probably well calibrated module : Moog uses middle C = 0V while other Euro modules assign 0V to the lowest MIDI note or the lowest note on a 61 key keyboard. regards
LRE 4x1 breakable RGB LED-Ring/Rotary-Encoder PCB bulk order
Dimduj replied to weasel's topic in Bulk Orders
I’m also interested !!!! -
Thx for the answer TK ! I already use the PRESET ad a default SESSION for the initial setup and it works easily . What puzzle me is he fact that I have to reselect the PRESET each time I go to a new pattern. If I change my mind about some instrument config (the channel for example) I've to edit each pattern to reflect that change Is this the expected behaviour or am i missing something ? I would expect that if I choose an instrument (PRESET) for a track It will be use for every new pattern unless I choose another instrument (PRESET) for a specific pattern? Are PRESET defined per track or per pattern ? Maybe the 'Save & Take over' feature could be a workaround for my first issue. Sorry for the late reply but i try to avoid asking super dumb newbie question and it took me times to explore the features and make a correlation between user manual with Wilba workflow and the new Midipy workflow;) Thx again for the support and congrats for this amazing piece of hardware I really enjoy it !!! Take care
I hope so !!! I’m so happy with the midi box seq v4+ amazing piece of software, hardware... and case ;)
Mmhh i’m not in the confidence so it is just a guess but I hope they will release a blm soon
Can’t wait to order the midiphy BLM ;)
Hi I’ve a midibox seq v4+ and one thing I struggle with is that each time I switch to a new pattern I have to reconfigure all the tracks setup (midi port, midi channel, track length). i probably miss something but is there a way to define the track setup globally or even better, per session ? i try to search on the wiki, and on the forum but didn’t have any luck i don’t mind editing some files directly on the SD card if it is the way to go but all I’ve tried do not works:/ thx for any suggestions dimitri
Hi ! Speaking of drum tracks, would it be possible to define one midi channel per instrument/drum and ( maybe with sort her track length?) a note parameter ? I also search in the forum but I think no one has ever ask it so I take the risk ;) would it be possible in the future to have more than 16 active tracks ... I now I probably ask for too much :p
Hi ! i’ m exploring the features of the midi box seq v4+ and I got some questions. Sorry because it is probably noob’s questions but I didn’t find informations on the docs... hope it is the good thread ;) What is the purpose of the MEC “Shift” button of the seq v4+ ? Is their a way to just copy a specific trigger/param. What if I just copy/paste the accent trigger but not the gate trigger between tracks ? How can activate the step forwarding when I do not record ? When playing with live mode activate the seq do not jump to steps over 16. Is this the normal behaviour? when in recording with live mode activated, the seq will. It jump to next steps ( 17-32) only once.is their a way to activate the forwarding not only the first time. Cheers
