Greetings Hawkeye,
I'm a bit of a noob on this machine, even though I've had it for a while. I've only just realized how powerful it is. I don't have the machine with me where I am so I can't confirm firmware version, but I build it several years ago and I've never upgraded the firmware since I put it together. But from memory it's version 2 of the firmware, since v2 seems to have been out since I built it and I downloaded the latest version at the time.
Is there a way I can edit the steps or the chord of the arpeggiator manually and make it step down instead of up? No matter how many times I change the direction of the arpeggiator, it always seems to be the same.
Does the multi Engine require more than two SIDs? Surely it's one SID per channel, or is that an incorrect assumption?
I'm going to read the entire manual tomorrow and see if I can work it out, but if that doesn't work I'm going to try and re-upload the firmware to the device.
Thanks for your response.
Squinton.
