The desk is a Soundcraft B800 which is an old broadcast desk. If you Google it, the first result should be the page on Soundcraft's website which has pdf manuals, tech specs etc. There are 3 identical PSU's which I thought I could tap in to for the 5V but it seems they only supply +48V and +/-17v. Dropping the voltage to the +5 which I have measured on the ext. mute pins must be done somewhere in the desk itself. This thing is not particularly easy to work on - even with all the channels removed, so I think I'm swinging towards using a separate power supply for the MIDIbox and the excellent suggestion of using optoisolators in place of the usual LED's. If I understand correctly, I will be keeping the resistors but perhaps a different value than 220R, depending on the opto used? Any suggestions for a good combination? Can't wait to get started on this!
