Ashiman
Members
  • Posts
    342
  • Joined
  • Last visited
Everything posted by Ashiman
  1. I beleive in http://gedlee.com ~ waveguide theory. check out the summa pdf. I think I buy the books & program as well. ...Doppler distortion should be real bad/articulated then with Tannoy dual concentric speakers, which apparently using the bass cone as waveguide, opposed to the Altec 604, which suffers because the horn in the middle shades the cone. I wont trade the JBL woofers for anything else, just try to simulate the 2235h in winisd ;D
  2. absorption vs . diffusion AFAIK you want to have diffusion cuz, these small nearfields have dome hi-freq transducers with wide dispersion , this makes early reflections a problem . You dont want to have early reflections cause then you are listening to your room ambience in the mix as well.
  3. /tilted/ or Jaicen ,you have degree or something similar? http://www.bobgolds.com/ best diy link in soundproofing.
  4. this topic should be split or destroyed : )) i heard all those hangdrums going out of tune and noone fixes them, hihi , the world is saved :P
  5. http://www.prodigy-pro.com/forum/viewtopic.php?p=317541#317541 Dale116.7 tells you what is the problem with soundbite ~ why he rolls his own
  6. actually, the good serial connection looks to be: 1. get the freescale (many ppl over synth-diy list bought it ) 2. detach the low quality codec 3. insert TAS3103a or TAS3108 in its place you can do the memory based FX on soundbite and filtering on the TAS and lot else.
  7. I'd look into ps3linux if I'd want to learn parallel audio processing -.-
  8. excuse me , uad stuff is no ordinary video card, just like this isnt the yesterdays vaporware thread. http://en.wikipedia.org/wiki/Chromatic_Research
  9. what about putting a parallel FIFO memory to the LPT ? And a DAC ? ;D
  10. the problem looks like to be : despite the 16bit DAC, the S&H section is not reaching anywhere near this resolution . With new TI opamps and expensive caps I think its possible to get closer to that bit depth.
  11. i dont like honesty voicing issues on this forum therefore i wont vote. :-X
  12. http://mailman.code404.com/pipermail/a6/2003-January/000815.html s&h quality depends on quality of capacitors , etc. maybe you can tweak it yourself once they wont swap it eitherway ;D
  13. m-audio is subdiary of pro-tools , the boutique kingz... real soundcard is Lynx , with working linux drivers :)
  14. Artesia has a thread about an opened NL3 , but im not sure he owns one right now. BTW i want to buy an NL 1 . http://homepage.ntlworld.com/nausicaa.valley/ucapps/INSIDE_NORD_LEAD/
  15. it took me 4 years to define i want to be materials engineer and another 2 to make it sure ;D
  16. i was talkin bout the chipfor replacement stuff. I promise I'll use quote button from now sorry. Who has a real 808 and mb808 ? Timing inaccuracy should be a feature no ? :) (for real)
  17. if someone jumps into those, then, well, ... good luck with front plate !! :-\
  18. yeah, the pdf is there .. and what a pdf!! very unusual architecture, makes me think of discrete version : )))
  19. I was w8ing f0r this , thanks r8ching out to Thorsten @ lab .
  20. anyone checked the intersil dac?! :P its a marvel , thx Artesia!!
