Matrix12x
    76
Everything posted by Matrix12x
  1. I would be very interested in this if it wakes from hyper sleep. :-)
  2. Has anyone integrated Seppoman's SSM2044 PCB and the AOUT into the MB6582 case? Anything to think about in advance? I was just wondering if any one has done this, or if it is primarily used as an outboard piece of gear.
  3. I was flipping through older topics and this looked very interesting. Was there any progress on the MBSID 32?
  4. I was just wondering, Were the files at the beginning of this thread updated?
  5. I should bother to read the manual. lol. thank you so much,
  6. I have a MB6582 that I built a while ago and it is currently running 2.043. I noticed an anomaly when I press any two of the "vertical" matrix buttons at the same time, the mode led switches from matrix to meter or vice versa. has anyone els sen this? the same does not happen when I hit to horizontal buttons simultaneously.
  7. Is there a US bulk order going on for the case currently? Also, does anyone have a case they are no longer interested in?
  8. Hi, Nice AU Component. Runs well on my iMac 2GHz 10.5.8 Intel. This is so cool, I can play with this at work, and nobody will notice, as compared to having my MB SID and some MIDI cables connected to my work computer... ;-)
  9. If I wanted to have the Sync LED change to display the status of say the Lead engines ARP function, would you use something like this: DOUT_ENTRY CS_MENU_L_ARP, 0, 16+1, 3 I am a little green at this and was just wondering. I changed the Sync button to be an Arp button and that worked fine when I recompiled, I just wanted to change the LED to display the same status. I saw that this LED was commented out, and thought this would be a good use.
  10. Oh... that was until I plugged back in my midid interface.... I think it is MMJ.
  11. Thanks, I turned off Java SE 6 64-bit and everything ran fine.
  12. I just noticed this in the last few days, but MIOS Studio suddenly stopped working. I am using OSX 10.5.8 on an Intel based Mac. It was working fine, and I am not sure what caused this. The MBSID editor program is also crashing as well upon opening. I saw someone in the german language forum seems to be having a similar problem. I think he stated that a previous backup of his OSX I reinstalled MMC, Java and my USB/MIDI interface drivers and nothing seems to help. As a side note, it works fine on my Powerbook laptop, OS 10.4.11, PowerPC. same version of MIOS, same MIDI interface. any ideas?
  13. sorry, I added that extra zero. Most of my cheaper headphones at home are less than 64 ohms.
  14. Most cheap headphones are about 600 Ohms am I correct? I thought the low impedance ones were about 100-150 ohms. I figure a simple circuit using a dual opamp like a 5532, a 1uF DC block to a 10K ohms on the non inverting input, 10K to gnd as R1 at the inverting input, 100K as Rf, and a 56 pF cap in the feedback to limit the BW, and maybe a 100-150 ohm series output resistor feeding a 1uF DC block to my headphones. I'll probably play with the feedback resistors value to match it to the gain I need. I have used this IC with as little as +/- 5VDC. A voltage divider to float the audio signal on the input at some offset will allow single supply operation. I'll breadboard something next week and let you know the results.
  15. Yeah, I think I am going to breadboard a quickie opamp headphone amp to put in there.It's way low in mine, almost inaudible. The line outs have loads of signal though. :-)
  16. On the MB6582.... Does anyone else think the headphone volume is way low? I have to double check my resistor values I think.
  17. It was my missing solder joints on the backs of the resistors. All now works great on the LED test and in normal operation. also of note..... When I hit any two buttons at the same time on the left side of the matrix, the matrix changes from matrix to meter mode and vice versa. anyone else see this behavior?
  18. I'm an ass. I just started measuring the resistors for the LED Matrix and the ones that worked had +5V approx. the ones that did not had 0V. I flip over my PCB and lo and behold missing solder joints on one side off all 5 resistors for the rows that are out. Gheez. I must of been distracted by my 18 month old whilst I was soldering. Thanks for the help and for the other LED test program.
  19. Thanks. All LEDs except the top 5 rows of the Matrix lit up. Is there anything in common with the first 5 rows that is not common with the last 3 rows?
  20. I ran the LED test program and I had no LEDs light, including the working ones. Is this because Wilba's LED Matrix is wired differently than the standard control surface?
  21. I just finished my MB6582, all works fine except LEDS in the Matrix for rows 1-8 - filter 1 2 3 and pulse width 1 and 2. i.e. the bottom 3 rows of the matrix seem to work fine. any ideas. I am going to check my wiring again and my solder joints.
  22. He said the most common failure was an internal regulator that they had to replace all the time with a different manufacturers part.
  23. I was at a party today and a guy there was telling me he used to work for a company in NY as a tech that was contracted to fix C64 power supplies in the 80's. He had a great memory and was telling me that some were built in the Dominican Republic and those constantly needed to be reworked. Just thought that was a weird party conversation from today that was relevant.
  24. After the control surface is finished, I will definitely be making patches and I will definitely be uploading them for others. I didn't know if anyone else was into swapping patches.
