Starfire
    32
Everything posted by Starfire
  1. BTW the letters are filled in with silver paint, if you are in the US I can include an adaptor, must be a regulated 12VDC supply
  2. Unfortunately I need to sell my sammichSID, it has two 6581's in it that I pulled from C64's myself. I specifically went with all white leds and the screen is white with grey letters also. It also has the plexiglass inset to protect the screen I've been building electronics for over 15 years so it's well made, I hate to let it go, it took a lot of time to get all the parts together but I just don't use it enough and along with the fact that times are tight I really need the cash. I'd like to get $475 shipped anywhere in the world, or $450 shipped in the US. Thanks
  3. Starfire
    sid3
    From the album: SammichSID
  4. Starfire
    sid2
  5. Starfire
    sid1
  6. Well It's been sitting for over a year now and in need of the cash, so thinking of selling it, but not sure if I need permission first? Thanks!
  7. somehow ordered the wrong encoders for my mb6582, anyone need fifteen 12mm bourns encoders?
    1. nebula
      nebula
      What's the part number?
  8. Mine works, I just have to finish the mb6582 to be sure it'll handle the power requirement, but proper voltages are seen on the 5V, 9V and 12v rails in the MB itself. Just a simple dual coil 9VAC transformer, one is rectified and regulated to 5VDC, the other is 9VAC straight in, of course some fuses just incase.
  9. I was just checking in to see if there was any news. :D
  10. Well been trying to get on here for a while, damn DNS problem, anyhow I got my parts and threw the power supply together and it works fine, I can't really run my mb-6582 as I am waiting for my front panel to finish it but I hooked it up and correct powers are seen on the base board for the 5v, 9v, and 12v, ran all the PICs and SIDs without any issue. I'll have to see when I finish it all, but I really think it'll be fine.
  11. Also there is this one, which has the same stats as the one I ordred but it's a PC mount, I wanted to be able to stand the coil on it's end to save some space so I got the wired version. My link
  12. Sorry it was a link from my search, should work now.
  13. Well I went ahead and ordred this transformer: Digikey Also got all 125degree caps for the DC side, I want this to work and last a long time! We'll see how it comes out. I did run across this schematic of the inside of the C64 supply, although we don't need that much amperage.
  14. Has anyone built a C-64 power supply clone, one that outputs the needed 9VAC and 5VDC. I'd like to build one but hate to reinvent the wheel if there are some good schematics out there that work well. Thanks!
  15. Yeah would be cool, I have a few atmels around here that could use a good home :D
  16. That's sad as all the time that went into building it and the thief will have no idea what it is.
  17. I can recommend the 12VDC regulated supply from all electronics it has ran my 6581s fine direct from the supply, puts out a nice constant 12VDC My linkhttp://www.allelectronics.com/make-a-store/item/PS-1251/12-VDC-500-MA-REGULATED-POWER-SUPPLY//1.html
  18. Starfire
    Starfire Tech
    My DIY stuff!
  19. I'm using this one: http://www.allelectronics.com/make-a-store/item/PS-1251/12-VDC-500-MA-REGULATED-POWER-SUPPLY//1.html 12.16 out under no-load and 12.09 under load, can't complain, cheap too!
  20. I plan on keeping one of the C64s I end up getting which ever has the nicest case. I never had one as a kid anyhow, just my atari. Gotta see if I can find a better heatsink I guess.
