highpow3rpc
17 -
Gender
Male
highpow3rpc's Achievements
midibox 64e 22encoder, 84switches, 64pots Need help
highpow3rpc replied to highpow3rpc's topic in MIDIbox HUIs
I know this is reviving an old topic but I would like to ask if anyone one could help with the coding/programming i've basically revisited it and its still causing a bit of confusion I now know the exact setup, 12 encoders, and 25 pots Would any one like to guide me through the process or even help write the application thanks in advance -
Hey Fozzy i was thinking maybe a dinx16 and an ainx8 Make it alot more compact and easier to integrate into mini builds Kind regards Highpow3rpc -
Hey nILS would it be possible for you to upload your schematic and board for us to have a look at, nah the thread isn't of topic still relates to the midibox64e and the bulk order doesn't sound like such a bad idea :) -
Thats the thing my sources of pcb manufacturers pricing is fairly high, at the moment i will be just building this midibox on vero board i will hopefully have a mock up board in the near future once the project is complete, kind regards Highpow3rpc, and would any one know where the best pricing for electronics components in australia is -
@phunk thanks heaps for the help i will refer back to this when i am ready to upload it, I have a question for you all, who would be interested in smd Ain, Din and Dout boards for tssop packaged ic's, and would these preferably be designed as smd passive components or through hole ? -
Fozzy i think that you may be right in the application being able to handle this, it just needs to be tweaked slightly in the configuration files, if then the app falls over i will post all progress in rewriting it. Kind Regards Highpow3rpc -
hmmm the idea was more to get insight/help in programming this think it might head that way pretty soon or hope for it to, would you be please be able to move this sorry for the inconvenience -
nILS this is exactly my understanding :), should i have put this in the software oriented forum ? basically i would like to re write the app for this purpose. -
In my reading it says that the midibox 64e supports upto 64 potentiometers in the newest firmware (2 ains) and if i am only using 22 rotary encoders that would be 44 inputs used on the dins, but if i am using 4 din's there is still 128-44= 84 leftover din pins, so wouldn't this still be possible with the single core Kind regards Highpow3rpc -
Ok i am a total noob and would like help customizing midibox 64e software to be mapped to 22 encoders, 84 switches and 64pots if any one would be able to help, or explain how to edit the files for this i would be very appreciative thanks all and by far one of the best online communities
Good luck with the box :) I hope to build something very similar to your controller, did you use any encoders or did use only pots and switches good luck with the rest of the project and hope it works well :) Thanks for the update. If at all possible would I be able to see a copy of the code and then once its revised as I would like to learn from seeing the code in practice. awesome project Highpow3rpc
Thanks findbuddha for the reply, i have been looking at the examples "MIOS32 C Interface" think its the same as the tutorials page, the system i would like to build will use all 128 of the digital in's (be good if there was slightly more so i could use all encoders and switches instead of pots) and 1 fader for fading between decks, thank you heaps for the links :), and any further help is much appreciated. kind regards Highpow3rpc
Hey i would like to bump this thread to see how you guys are going with the project, i am trying to do something similar :) but am stuck with the software side of things i have no prior knowledge of programming if any one can help please pm me i would be very grateful, thanks in advance
Hello all I am building a midibox core32 for traktor I am stuck and would like to ask a couple of questions 1st if I buy the module from smashtv will i have to do any other software/configuration prep work or can i plug the modules straight in plug the usb into the pc and it recognise all the buttons/faders/encoders ? 2nd if it wont parse controls to pc how would I do this (I have no experience coding)
Hello i am in a similar situation as you, i would like to use the core 32 module from avishowtech would i be able to use the module and hardware straight from the get go or is there more to it ?, thanks i am a noob also
