2wice
13 -
2wice's Achievements
I've also ordered the parts to try this. I'm going to concentrated on getting the mechanicals right before trying the software parts. Because the action on my Wurli's are very loose, and the tolerances are tight I thought of trying a disc or a strip of plastic with with 0.1mm slits every 0.5mm. I'm hoping to the sensor will be able to pick up such small apertures. It might be able to to calculate aftertouch then.
Thank you Thorsten, I'll give this a try.
Anyone have any spare motor faders they would like to sell please?
Hi All I would like to midifi a Wurlitzer electronic piano, while not affecting the current sound and action. Would it be possible to use the these; http://za.mouser.com/new/vishaysemiconductors/vishay-TCxT1350X01-optical-sensors/ with MBNG? These switches can measure speed also, would this allow me to calculate velocity on the MBNG? I'm looking for a contactless solution, if there are other options to accomplish the same then I would love your input. Regards
Good day. I just bought 7 Wurlitzer 206A Electric Pianos for $100.00, with the intention of stripping one and building a MBNG + midi keyboard into it. After trying the keys of one and finding it buttery smooth, would I be able to use the existing keys with the MBNG in some way? Regards
Hi all After nearly 10 years of waiting I finally built my 1st mb module. Thank you to TK and all involved, I'm all giddy from excitement of the possibilities going forward. Regards
I think it worked, but LED2 on the target side faded in 3 times instead of LED1 on the link side as per instructions.
Hi I'm trying to flash the LPC1769 the first time according to the instructions. The status LED does not fade 3 times as per instructions. How can I confirm that it worked? Win 7 64bit, bootloader v1.012
Thank you very much Marxon
Thank you very much, Thorsten. I will follow this route then. Regards
Thank you for your advice. Are there any benefits other than aesthetics to building a keyboard controller? It would seem better to do the logic part and not worry about the other.
Good day all. I'd like to start a project constructing a controller for logic with a built in midi keyboard. The controller part I have planned (some hardware ordered already) and expect will work. I have a kb that does not work with os x ml via usb but should work fine via midi. I was thinking of stripping the kb and building the keys and internals with the mbng control surface. My question then, would it be best to keep the original keyboard electronics and using the midi to interface, or somehow integrate the keys only through the mbng? And is the later even possible? I have been lurking around here since deep in the last decade and I have to mention that I believe that there is something reaaaaaly special happening here with the mbng. Well done to TK. and all involved, it is really awesome work. Regards
