Fietspomp
    5
Everything posted by Fietspomp
  1. So that hand angle/shape dictates different relations between each parameter, right? That was indeed one of my thoughts, but since I'm using my own software anyway so I can explore many possibilities : ). Can't wait to get building. Thanks for the tip on the STM32, I guess I'll buy that than. After this project I might build a bigger version anyway and the extra spec might come to good use.
  2. I have been reading in to midibox a bit more, and a question popped up, would I need a 32bit module or will 8bit do? I'm leaning towards 8-bit as I think my midicontroller is simple enough not to warrant 32bit, however how do I attach both usb and midi ports to this bare looking module?
  3. Well I am glad someone like my idea! I think I get what you're suggesting I can use it as a crossfader with an extra property for light intensity (adding a third mixing element), right?
  4. As a host? I thought I just drew USB as it looks in the real world I guess it looks like a sata connection (if that's what you're referring to) too. Incidentally it is the wrong type anyway, I need to change it to usb connector type B which is what core32 module has. The plan for the ldr's was to have a more organic way too change values, by 'feel' rather than pin point precision dial. It also allows to control many different parameters at once and quickly consecutively. Beyond this I want to implement a gesture system in the future. Since I am building my VJ software from scratch (in OF/c++) I can accommodate this kind of input. The feedback idea hadn't crossed my mind but it is nice idea, mounting an led 'belt' or similar on top of the controller with delayed ldr data lighting them up would indeed yield some sweet results. Fietspomp
  5. I have designed a very simple midi controller with 17 inputs some of which are LDR. It's use would be as a controller for VJ software. It features 15 pots and an lcd screen with two buttons, to view and change the current preset. As this is my first midibox project, I would appreciate any design comments or suggestions! I recon I need: 1 x 32-bit core module or 8-bit not sure 2 x AIN module (for 12 x 2 = 24 analogue inputs) 1 x 16x2 LCD module 1 x Bankstick 1 x power adapter 2 x push button 1 x power button All at 10kOhm 5 x slide pot (50mm travel) 5 x turn pot 5 x ldr light sensor UPDATE: corrected usb symbol to match usb-b on the core32 module
