lipi
    4
lipi's Achievements
MIDIbox Newbie
  1. lipi
    Midi Merger
    So... the problem is solved I hope. Today I programmed my 16F88 with WinPIC. I hope it was succesfully.
  2. lipi
    Midi Merger
    Hi there! I just wanted to build the MBHP Merger with PIC16F88. I build the burner, it's work fine :) I want to burn the code into the 16F88 and I'm failed. Are you sure the hex code for the 16F88 is correct? Because when I burned the code into the PIC, then the PBrennerNG say: it's an 16F84 :( And I can't reprogram the pic :( In IC-Prog when I load the hex file, the asm list is started like that: LIST P=16F84, F=INHX8M include "P16FXX.inc" ORG 0x0000 BCF PCLATH , 03 BCF PCLATH , 04 ..... Is this correct? There is anybody who is burned the 16F88 with the MBHP burner & PBrennerNG and the merger (PIC) is work fine? Thanks for all! Cheers!
  3. lipi
    Midi Merger
    Hi All! Cas! What kind of burner and "program" did you use? I use the MBHP burner with PBrennerNG and the hex file from the http://www.ucapps.de/mbhp_burner.html but I'm failed to burn the code to the 16F88. The burner recognized the chip as a 16F84 :-/ Thx forward! Cheers!
  4. Hi there! I'm in the same shoes like Mo... Can anybody help me??? Please!!!
