So after four years today I finally bit the bullet and ordered a SEQ CS PCB and a LPC17 core board. I started doubting this decision soon after as I bumped into something only mystically refered as "the future MIDIbox SEQ V4 Plus firmware", which apparently requires the newer STM32F4 board to function. I guess I could still try to change my order to get the STM32F4 board instead, but here's what's on the top of my mind:
Is it worth it? When will it be available? Where can I find more info? Constructing a MBSEQ with the LPC17 board seems so much easier because it seems to have all the needed connections on the board itself. If I decide to go with the STM32F4 board, what boards do I need for external connectors? MBHP_ETH goes for ethernet, MIDI I/O modules for MIDI ins and outs, but what for USB and SD card slot? What about the CV/Gates port? Is it really needed if I don't have analog gear? What's the difference with MIDI I/O board and quad IIc_MIDI board? Can I install a BLM without the IIc_MIDI board?
After I acquire all the needed boards; am I able to cram them all inside the case? I'll be using the acrylic case designed by smokestacksproductions. I read somewhere that fitting everything in a Heidenreich case is a bit tricky. I'd like to hear also some tips on how to attach the boards on the bottom part of the case. I've seen some pictures with hot glue and spacers.
If anyone has build a MBSEQ with these hardware specs, I'd be happy to hear about your solutions and to see pictures of the insides.
Any answers are appreciated. Thanks!
