Stormcaller
    11
Everything posted by Stormcaller
  1. So I made this... https://soundcloud.com/thestormcaller/three-minutes-to-midnight I made this with Ableton Intro, a sammichSID and lots of bodging, and a good bit of advice from the Midibox IRC channel :)
  2. What are the differences between the v3 and the v2 aside from the different display?
  3. SmashTV bugged me on IRC to link this here. I'm going to make more, but I have some latency issues, and was getting glitched audio from the sammichSID for some reason when Ableton was sending midi notes to it. I'll work on that.
  4. Oh, It might be too late for this thread but people forgot to mention one option. Get a kit then get someone else to build it for you :)
  5. I built mine in about 6 hours including troubleshooting, perhaps a little more for paint drying and so on. I just worked on it a little after work each day for a few days. I didn't have that good luck with getting SIDs and Wilba bailed me out in the end as I kept ending up with defective ones. As for whether he has any kits left, or whether he has any 6582s left you'll have to ask him directly. Failing that finding commodore 64s will eventually get you some working 6581 sids if you get enough of them, but finding fully working ones is a needle in a haystack, and I prefer the sound of the later SIDs after hearing them next to each other anyway. I have a defective SID around here that is good for testing (filters are gone but it makes sound) if anyone wants it.
  6. In theory could someone take this board, wire the output to a second board with multiplexers on it to connect to J2 on a sammichSID and allow you to connect a modulation matrix to one as an external unit?
  7. Heat up all the joints at once with a mini blow torch and whack it on the desk.
  8. Thanks for that, just cranked it up to 12V and now looks better. Edited to add, screen stopped working again while I was moving sid chips around so I decided to resolder the entire thing a third time, now working again so must've been a really stubborn dry joint.
  9. ...and the screen has just spontaneously started working for reasons I cannot fathom. Plugged my chips in sans sids which I don't have yet and it is booting fine. Screen is working with the low power jumper config.
  10. Tried it with JP4 both on and off - when on it was only for a very short time to see if I could get a response, but nothing. I have not tried 12v and won't do so until I get some confirmation as to what the correct settings are.
  11. If that LCD is at 5v 260ma if I read the sheet right doesn't that mean it should be set up as a low power LCD on the jumpers? My order stated that I would be shipped a high power one and I am just at the stage of setting up the jumpers now so was asking on here as the LCD has "5V" written in large friendly letters on it. I thought feeding it the 12v for a high power LCD may not have been a good idea without asking first so I came on here and found this thread. Also, just to vent, I was outbid on the C64s I was bidding on... Oh well it might be a while longer before I get those sids :)
