mr_kholl Posted March 28, 2008 Posted March 28, 2008 Hi,I'm one step to order some ALPS 60mm motorized faders from a supplier, but first, i need to check if it will work on MF module, because its resistance value is 5K instead the usual 10K (I.E. RSA0N11M9).This is the datasheet: http://www.modtv.com.br/mr_kholl/402331_RS60N11M9_5KB.pdfPS: You will see on the specs that this fader has the same pinout of the RSA0N11M9, including the 'touch sense' pin.Does anybody can inform me it?Thanks in advance.Kholl.
Screaming_Rabbit Posted March 29, 2008 Posted March 29, 2008 Does anybody can inform me it?... as far as I know, nobody ever tried this. Though there are many successfull implementations of regular 5k potentiometers.Theoretically it should work but you have to try. - Just buy one or get a sample and do some tests.Greets, RogerPS: You can search the forum for the regular 5k pots to gather additional information.
mr_kholl Posted March 29, 2008 Author Posted March 29, 2008 Hi Roger!!Thanks again man.The problem is that i'm in Brazil and the seller in Germany!! hehehe...expensive shipping cost and long time to arrive here. I have to do it in one shot.If anyone else can inform it i really appreciate. Maybe some modification on MF driver...Roger, anyway i will search about the 5k pot issue.Thanks!!!Kholl.
Screaming_Rabbit Posted March 30, 2008 Posted March 30, 2008 If you buy them from a supply store, why do you go for 60mm? Believe me, you won't be satisfied.Greets, Roger
