Always keep a tidy workspace
#21
Posted 03 May 2008 - 00:35
#22
Posted 03 May 2008 - 01:22
BTW- How do you guys post the thumbnail pictures that link to the full size if you click them (or is that something I'm supposed to know how to do with stuff on Photobucket :-[ ;D)??
#23
Posted 03 May 2008 - 08:54
... or is that something I'm supposed to know how to do with stuff on Photobucket :-[ ;D)??
Jidis = "MidiBox Guru" = Yes!!! You have to know!!!
But don't ask me, I don't know it neither ;D
Greets, Roger
(Sorry could not resist ;))
#24
Posted 03 May 2008 - 09:44
Tick the "+ Additional Options..." below the text input field and select the picture you want to attach from the search dialogue - voila! ;)
Best regards, ilmenator
Edit: Also, you can make sure that the picture is not wider than ca. 600 pixels - this way, I don't have to scroll sideways to see the whole picture at once. This scrolling thing is somewhat annoying as the scrollbar is very often located off (below) screen and I have to scroll down first to be able to scroll right...
#25
Posted 03 May 2008 - 15:08
... (might make you feel a little better)...
that's what i'm talkin bout!
here's my full shot.
note the special attention to general tidiness, which ensures successful completion of projects
This was fun while it was around:
that thing is a great idea, mb-dev_brd...
#26
Posted 03 May 2008 - 17:03
#27
Posted 03 May 2008 - 17:24
how you manage to cut that cable and with that precision?
seems like you already bought it pre-cut to the given length..
#28
Posted 03 May 2008 - 18:33
wilb', i got a question;
#29
Posted 03 May 2008 - 18:46
I had this one too. It's the worst thing I've ever seen.
#30
Posted 03 May 2008 - 19:11
Got it! (and resized the 640 to 600) I actually try to bump things to 640 for that same reason, but I guess 600 will be the new width if it's safer in that regard.
BTW- That help page for the forum posting is a work of art. I either hadn't read it, or purged it when some new stuff went in my small-ass head. ;D
I guess it all requires using actual post attachments rather than an outside picture host. It's a shame you can't place them within the text though.
Yeah, it was nice. Mainly just because I could compile and dump an app to it, tap some buttons to see how it ran, then change it and re-dump while sitting and staring at the same area. I had to lower my monitor platform recently to accomodate a 3-space rack though. Maybe I can build a new one into the monitor stand or something that hangs at the top of the screen. Wonder if I could fit one into this stupid "multimedia" keyboard I'm using which already has transport and volume controls that barely work with anything. (I was planning a nicer PS2 keyboard MIDIbox long ago for the studio, but I'm out for now and won't need it :'()
Take Care,
George
#31
Posted 03 May 2008 - 19:19
Wilb', i got a question;
I'm wondering more about those neat clean raw wires sticking out of the insulation.
That's one thing I dread about ribbons, nothing can get in there to strip them easily. His look tinned or something too (mine are always all fuzzy looking :-[).
Those boards really are beautiful by the way!
#32
Posted 03 May 2008 - 19:44
This is a random google image link, but quality tools like this really exist. ;DI had this one too. It's the worst thing I've ever seen.
#33
Posted 03 May 2008 - 21:35
sedatives might be very useful when extensice cable stripping is needed ;D
#34
Posted 03 May 2008 - 21:45
There is even a wikipedia article about those tools.
this one matches the one I'm using:
#35
Posted 03 May 2008 - 22:05
In Poland it costs not more then 2E and can be bought at several brand. I still have scars on my hands after screw which handle blade suddenly got broken. Most wonderfull tool I've ever seen.This is a random google image link, but quality tools like this really exist. ;D
#36
Posted 04 May 2008 - 07:35
100mil (0.1") spacing ribbon is thicker than the 50mil (0.05") spacing kind, the wire is multi-strand and pre-tinned, but if you nick it a little then when you bend it, it breaks at that point. However, because the wire and the insulation is much thicker, you don't need wire cutters, and can cut the insulation with a knife and pull off the insulation from each wire.
The best way to strip the insulation from the wires is to lightly score with a knife on the flat side, i.e. cut half-way through the insulation, not cutting to the wire, then do small cuts between each wire (from the score line to the end), then pull off each little bit of insulation with pliers, being careful not to grip the wire too much and pull the wire out. What you do not want to do is cut, scratch, dent, damage the wire in any way, because if you do, the wire will break when bending. Then use the holes of the PCB to bend the ends of the wire - insert cable so 2mm of wire (about the thickness of the PCB) is visible between the top of the PCB and the start of the insulation, then bend 90 degrees. I bend it so the ribbed side of the cable will be on the inside.
#37
Posted 28 May 2008 - 22:17
#38
Posted 29 May 2008 - 00:09
#39
Posted 29 May 2008 - 09:45
I like your lab cimo - looks not uberexpensive but definitely functional
#40
Posted 29 May 2008 - 10:33
in fact over 50% of what you see it s either second hand stuff or recycled stuff, the pc under the desk is a machine built with stuff i ve found on the street and got for free.I like your lab cimo - looks not uberexpensive but definitely functional
By using a laptop hard drive and supplying the fan with the 3.3 voltage section plus a little trimmer i got a far more silent machine than most of commercial unit you can buy nowadays.
Simone
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
