Anybody any luck with connecting two linux machines with midi over the network?
I know netjack is supposed to do the job, but the Rosegarden sequencer only takes the ALSA midi ports.
I am now considering falling back to the Multimidicast software.
  • Replies 130
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Much voodoo exists over this. Obviously you've already found the two best solutions currently in place - NetJack (best, if you use Jack) and multimidicast (for ALSA Sequencer ports). I guess f you can't use jack, try multimidicast and see how you go.
Good then Multimidicast it will be.
To get back to the topic. I played a little with MusixGNU. A dedicated distro for  musicians and artists. I think it is till too big (Don't need printers, graphics editors) and not everything is properly translated in English if at all.
I did not manage to install it on the harddisk.
All the nice musicial tools are there though with all the proper options. Good work.
I've put a lot of work into it so far, and all based on ubuntu studio... I think it's a bit too late to try other distros now.
Fortunately I've managed to find various packages for the later versions of the tools we need, and while I wait for a couple of things to reach completion, I want to start filling out the PPA with those packages. After that I'll make up metapackages and package up the stragglers, and it'll be ready to roll :)
  • 2 weeks later...
Any ideas when it'll be finished? I need it for a school project!  ;)
Good work and thanks for all your time on this, I can't wait to see the end result!
hehehe it's getting there!
At the moment I'm spending a bit of time ironing out the details with the way a few things interact.. yaknow like, getting DVD codecs to work with subtitled movies, which means removing the standard video player that uses a gstreamer codecs backend and replacing it with the same app that uses a xine backend... For the end user, this takes only two lines in a script to do, but takes me a week of troubleshooting to pin down... and other annoying small scraps like that....
I think that all efforts will be a waste if people try to use this thing and it just won't behave, noone will bother to use it ;)
Anyway if you've got some diskspace to spare, you can start with WUBI (runs ubuntu in a VM within windows) or better yet ubuntu studio, and I can supply you with a list of repositories and packages to add to the system, so you can try it out...
