adding C codes in asm application
anakin
Hi
I'm doing some tests using the application sm_example2_v1b that is coded in ASM.
The apps for me is quite difficult also because i'M not able to code in asm but quite well in C.
question: is it possible to add some lines in C inside the code in asm? in which way?
Do I have to create a new file called , for example main.c and code inside or I have to do in other way?
thank you for your precious help!
Anakin
check out sm_c_example2 :)
http://svnmios.midibox.org/listing.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fexamples%2Fsm_c_example2%2F
No, it's only possible to add assembly code to C routines (but it's very tricky and not straightforward)
Mostly it's easier to place assembly functions in a separate module, and to call the assembly code from C - this is demonstrated in sm_c_example2
