hello,
I try to connect a bank stick to IIC-port and a
character LCD to J15. When the Bankstick is not
connected, everything runs fine, if the stick
is connected, the LCD won't work anymore,
but the application is running normal.
I did not yet check if Bankstick reads/writes work.
Is it a problem to have a bankstick and character LCD
connected at the same time?
PIN 28 of  the PIC is used for both IIC and LCD port.
What is its function?
thanks, this
hmm... I think no. I just disconnected the SRIO boards, the problem
stays. the DOUT-issue is not a malfunction in this way, it's just kind
of confusing..
the test app works as expected, only the MSB/LSB of
the DOUT-registers are swapped. the single registers appear in the
right order.. and with the ribbon cable wiring you have very few
pontential wiring bug sources :-)
I'll check the Bankstick wiring, maybe some solder-bridge or something
(as I already had on a core PCB this mornig..)
some more pics..
3791_imgp0690_jpgb0d9f689697b52d2b5fa39f
3793_imgp0695_jpg512782463050ab96ac2e874
problem solved....
me idiot made a shortcut with the mounting screws for the
little bankstick-bord..
but the DOUT-issue still remains.
