Sign in to follow this
Followers 0
Sasha
XBee wireless bi-directional MIDI link
18 posts in this topic
15 Miles!? Good Lord.
Hmm. After hours, get up in the drop ceiling at work, wire up the audio of my monosid to the PA speaker in my office. Next day, come in with my wireless XBee and start sending SID sounds throughout the office randomly...
Share this post
Link to post
Share on other sites
Awesome!
I was worried about the range you could get with this thing...
Only thing I was worried is latency, but it is just 5.5-6ms. :)
It is not very cheap to make, but it is much cheaper than commercial products.
Share this post
Link to post
Are there any handshake-routines implemented?
A corrupted SyX-transfer could be a bit bad actually...  :P
It would be cool to get it work without PC. like the M-Audio wireless MIDI-stuff
Share this post
Link to post
Yeah, youd prob end up taking down a plane or something!  :P
Share this post
Link to post
It can work without PC. I`m not interested into using it with PC myself, if I would I can always connect it to the GM5. ;)
Share this post
Link to post
connecting to the gm5 was my first thought too.  we had to write a paper at work on various wireless communications, and this was one of them.  but i never thought of using it for midi.
don't you think the latency might be a problem?
Share this post
Link to post
5.5-6ms?
Share this post
Link to post
5.5-6ms?
Not if you dont mind the latency of a decent audio interface, which would be about 5-6ms id imagine, without artifacts in the sound of course.
Share this post
Link to post
I just finished putting one together:
I haven't done a lot of testing yet but it seems to work.
Share this post
Link to post
Cool! Let us know the results of testing.
Share this post
Link to post
I'm really curious about jitter on this (latency timings are given but jitter is not - jitter will be a big issue with clock signals for example) ... look forward to the test results!
Share this post
Link to post
Well, I've done some testing now and have since upgraded the original XBee's to the Pro version in an attempt to get better range.  I'm using the ones with 'chip antennas' and I understand you can get much better range if you use proper external antennas.  The Pro radios work around the lower level of my house, around/through walls, etc.
I've pumped a lot of MIDI sequences through without any obvious issues, and would be happy to do some real testing if y'all let me know what you want to see and how to do it.  I'll give it a shot at least.
As an aside, for MIDI I'm using a Roland serial driver and not the Korg driver mentioned on LadyAda's site.  I couldn't get the Korg driver to work properly.
Share this post
Link to post
Glad so hear it works good!  :) I have no idea how to test it more intensively.
Share this post
Link to post
Fun! As for testing.... do you have a scope?
Share this post
Link to post
I could borrow one...
Share this post
Link to post
Good news :) The reason I ask is, that you can't really use a PC to test timing, because the timers on them that would be used as the time reference...well... suck. Likewise they can't be trusted to generate the signals you're testing... fortunately we have midiboxes for that ;)
Probably the easiest way to start a test, would be to push midi clock from a midibox, across the xbee link, and use your scope to measure the serial output pin on the receiving-end xbee. Because midi clocks are 0xf8, you should get a fairly decent square-ish pulse out of it every time a clock message is rec'd. Then I guess take a walk around with them and see how it fares...
Share this post
Link to post
Followers 0
