MPN Posted April 30, 2009 Report Share Posted April 30, 2009 I’m using the MIDIbox SID 2 engine and a AOUT_NG to control an analogue synth (a TB303 clone). The pitch-cv is controlled with the AOUT_NG and the gates from J5 on the core. With the bassline engine it’s possible to forward the internal gate, slide and accent signals to J5. This works when the sequence is running. But when I have direct control mode and play from my midi-keyboard only gate and accent work. When I press two keys at the same time there is no signal on the “slide-pin†of J5. Is this normal or is there something wrong with my setup?Best regardsMagnus Quote Link to comment Share on other sites More sharing options...
TK. Posted May 2, 2009 Report Share Posted May 2, 2009 Is this normal or is there something wrong with my setup?Thats normal, but I will improve this in one of the next releases.Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
MPN Posted May 3, 2009 Author Report Share Posted May 3, 2009 Thank you very much! :DMagnus Quote Link to comment Share on other sites More sharing options...
