Technosoul Posted July 19, 2009 Report Share Posted July 19, 2009 Well I have a few questions. I am building a midibox 6582. Everything is put to geteher, all joints good.I have just connected wires from PCB to CS PCB. I expected to see some LED's light but nothing.Also I have download mios studio and V2 mios to computer for uploading. I have connected my LCD with proper wiringWell, I'm at a lost. I have read the documentation and I am just at a lost as to how to upload mios, not sure what I am doing, wrong or right. I am using a USB to midi cable from Mididbox to computer.Everything is just seeming really foreign at this point.If anyone can help....awesome Quote Link to comment Share on other sites More sharing options...
lylehaze Posted July 19, 2009 Report Share Posted July 19, 2009 There are questions...Did you buy your PIC from Mike or Smash?There are a few steps..Burn the bootloader into the PIC (requires a PIC burner), not needed if you bought it from Smash.Set up your computer to run MIOS studio.Load MIOS into the PIC using MIOS Studio.(not needed if you got your PIC from Smash.. I THINK)Load the application into MIOS using MIOS studio.Try this link for details:http://www.ucapps.de/mios_bootstrap_newbies.htmlIf you have troubles, test your MIDI interface by doing a loopback test.All the details should be on the page I pointed out.Have Fun,LyleHaze Quote Link to comment Share on other sites More sharing options...
Technosoul Posted July 19, 2009 Author Report Share Posted July 19, 2009 the ones I got from smash have mios v1.9. so I went to load sid app. If I choose wait for upload request, nothing happens.If I choose manual mode, blocks are sent.also, what does this mean... F0 00 00 7E 40 01 01 F7, recieved when I did the loop back test Quote Link to comment Share on other sites More sharing options...
Wilba Posted July 20, 2009 Report Share Posted July 20, 2009 Maybe you didn't put a jumper in J11 to select which Core is connected to the MIDI Out port.Thus you're not receiving the upload request from the Core.Note also you'll need to change the device ID in MIOS Studio to target the upload to each Core (the PIC with that device ID already set). If you get PICs from SmashTV, they will already have ID 0,1,2,3 set and printed on the label. Quote Link to comment Share on other sites More sharing options...
Technosoul Posted July 20, 2009 Author Report Share Posted July 20, 2009 so I dont know what happened but I went to upload sid app into PIC 1 and it load bloacks and all check sums reported OK. Is this a good thing?Now do I need to repeat for the remaining PIC's Quote Link to comment Share on other sites More sharing options...
Technosoul Posted July 20, 2009 Author Report Share Posted July 20, 2009 OK, Loaded app into PIC, 1, 2, 3 but 0 is not accepting Quote Link to comment Share on other sites More sharing options...
Technosoul Posted July 20, 2009 Author Report Share Posted July 20, 2009 wait, turned midibox off and on and now #0 PIC is loading Quote Link to comment Share on other sites More sharing options...
Technosoul Posted July 20, 2009 Author Report Share Posted July 20, 2009 holy smokes, I'm making noise, ohh shit I cant believe it. but still no LCD. Quote Link to comment Share on other sites More sharing options...
Wilba Posted July 20, 2009 Report Share Posted July 20, 2009 Make sure there's no shorts between LCD and the control surface PCB. (Hence instructions to solder cable to "bottom" side of LCD, and use something to insulate pads on the "top" side, like sticky tape.Perhaps initially try with LCD not attached to control surface PCB.Do you get any backlight or black bars on the LCD? Quote Link to comment Share on other sites More sharing options...
Technosoul Posted July 20, 2009 Author Report Share Posted July 20, 2009 yes I do have a back light.lets see if I can post a picmb.JPGmb.JPG Quote Link to comment Share on other sites More sharing options...
M.U.L.E. Posted July 20, 2009 Report Share Posted July 20, 2009 holy smokes, I'm making noise, ohh shit I cant believe it. but still no LCD. that made my day :) Quote Link to comment Share on other sites More sharing options...
fussylizard Posted July 20, 2009 Report Share Posted July 20, 2009 Silly question, but have you tried adjusting P2_CORE1 (contrast for the LCD)? You can also fiddle with P1 to adjust the backlight level. Both of these are the pots located on the base board in the lower right quadrant near J11 (where you select the core for MIDI Out). Other than that just verify your LCD is wired properly (getting the backlight is a good start). Quote Link to comment Share on other sites More sharing options...
Technosoul Posted July 20, 2009 Author Report Share Posted July 20, 2009 Silly question, but have you tried adjusting P2_CORE1 (contrast for the LCD)? You can also fiddle with P1 to adjust the backlight level. Both of these are the pots located on the base board in the lower right quadrant near J11 (where you select the core for MIDI Out). Other than that just verify your LCD is wired properly (getting the backlight is a good start).I'm going to try this out when I get home from work today. I think some of my front panel led's arent working, but cant really be sure until I see the function. Also maybe some of the encoders are slow to rspond, but once again I cant really tell until I see values change on LCD. But after doing a couple tweeaks this machine is going to be sick. Quote Link to comment Share on other sites More sharing options...
Technosoul Posted July 21, 2009 Author Report Share Posted July 21, 2009 adjusted pots for lcd and all is good. I had to replace a few wires that connect CS PCB and main PCB. Installing and stripping those wires has been my most difficult task. Right now I have the MIDI BOX connect to a MFB-step64, just running sequences. Theres a few things I need to go in and figure out after just playing around and tweeking knobs. I'm noticing my lfo rate seems to not be right, not a huge variation in speed and also the release on envelope, doesnt seem to carry long tone lengths.Hey, I just wanted to say thanks to everyone has helped with my posts and thanks to all you guys that have created this for the community to enjoy building. If they would have required building electronics like this in school, my career and life would be completely different. I wish had a little more knowledge of the electronic parts used, but I think I will figure some things out as I play around and get into the mios.this project has been sick, thanks again, wilba, avi show tech, tk, fussy everyone Quote Link to comment Share on other sites More sharing options...
Wilba Posted July 21, 2009 Report Share Posted July 21, 2009 Good to hear it's all going... can you post some show-off pics? ;) Quote Link to comment Share on other sites More sharing options...
Technosoul Posted July 21, 2009 Author Report Share Posted July 21, 2009 yes , show off pics are coming after I install the feed back pots which should be happening later this week Quote Link to comment Share on other sites More sharing options...
fussylizard Posted July 21, 2009 Report Share Posted July 21, 2009 Woohoo! Glad to hear you're sorted out then! After all the help I got building mine, I'm glad I could pass along some love. :-)I'm still sorting through all my pics and what-not from my build so I can post a summary, parts lists, etc.Looking forward to more pics from you. Quote Link to comment Share on other sites More sharing options...
