k2z3k0 Posted October 8, 2017 Report Share Posted October 8, 2017 hello Thorsten pre2 works great! last thing if possible,could COPY,PASTE also copy and paste mixer map? thank you K Quote Link to comment Share on other sites More sharing options...
TK. Posted October 8, 2017 Author Report Share Posted October 8, 2017 Fine! :) For common users the relation between patterns and mixer isn't obvious, it could be very confusing. Especially for those who use only a single mixer map for all patterns. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
k2z3k0 Posted October 8, 2017 Report Share Posted October 8, 2017 (edited) Thank you so much Thorsten! Totaly understand mixer map thingy Kind regards Kazik Edited October 9, 2017 by k2z3k0 Quote Link to comment Share on other sites More sharing options...
k2z3k0 Posted October 12, 2017 Report Share Posted October 12, 2017 hi Everybody did anyone brought up idea of incoming data is recorded(directed) to the tracks that are set to same midi channels that is originaly coming from? basicaly mutlitrack(multichannel) recording? my idea is option that listen to one selected IN port and accordingly to current incoming midi channel it selects current track for recording on the mbseq with the same midi channel set or other way it record(direct) data to track on mbseq with out changing selected track best regards Kazik 1 Quote Link to comment Share on other sites More sharing options...
k2z3k0 Posted October 13, 2017 Report Share Posted October 13, 2017 hi there i suppose first option is easier selecting current track in mbseq by checking incoming midi data actualy now thinking about it it could be very handful not only for recording but also just for editing ,example: turning knob lets say for Pitch Bend,Channel 1 on my external midi controller switches current track on mbseq accordingly and thus i do not have to do it myself every time,and when moving my attention to mbseq current track is same as channel of last edited incoming data bests K Quote Link to comment Share on other sites More sharing options...
FlavioB Posted October 15, 2017 Report Share Posted October 15, 2017 Hi k2z3k0 - ain't it already possible to use some sort of "master keyboard" on which you play notes and direct them to a track on the SEQ V4? Or did I misunderstand something?! And at the same time, having the notes being forwarded to the synth/unit you're playing... F. Quote Link to comment Share on other sites More sharing options...
k2z3k0 Posted October 15, 2017 Report Share Posted October 15, 2017 Hi Flavio Yes this function works flowles already To make myself clear, Lets say i have track 1 to 8 on mbseq,and this track are on channels 1 to 8 accordingly Now Lets say my master controller have 8 knobs each sends pitch bend to channels 1 to 8 Now if i want record pitchbend for each channel 1 to 8 I need to record track by track changing curent edited track, and i can use only one knob So i thought could it be possible that if i can hit REC And then having 8 knobs adressed 1 to 8 ,depending from what knob i turn Mbseq will record it to track that is adressed to according midi channel Basicaly if im in REC and send pitchbend on channel 3 I would like mbseq to record it to track adressed to channel 3 No matter which track is selected As for now doesnt matter what channel incoming data come from It will be recorded on currently selected track only Other idea was function you can turn on/off that is checking Incoming midi channel and it will select current track according It could work in REC as well as on EDIT mode Sory i went a bit long,just wanna be sure you get me While working with REC mode i felt that could be a huge step towards improving live performing flow So that plus pattern copy(thank you Thorsten) Would open up work flow greatly in my mind Thank you Let me know what you think Bests K Quote Link to comment Share on other sites More sharing options...
TK. Posted October 16, 2017 Author Report Share Posted October 16, 2017 I added this request to the wish list, but note that due to the much higher memory consumption (recording structs will allocate 16 x more RAM) such a feature would only be feasible with MBSEQ V4+ running on a STM32F4. It can't be made available for STM32F1 or LPC17 Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
k2z3k0 Posted October 16, 2017 Report Share Posted October 16, 2017 Hi Thorsten understood thanks for adding it to whishlist and what about implementing only function that can be turn on or off that would change CURRENT track by listening channel from selected midi in? bests K Quote Link to comment Share on other sites More sharing options...
TK. Posted October 16, 2017 Author Report Share Posted October 16, 2017 This will lead to unintended side effects which have to be avoided. E.g. the recording (and live) function has to keep track of the played keys (and it also measures the delays between Note Off and On) - by switching to another channel, this information will get lost and the recording function won't work properly anymore. It's the same place which has to be made ready for 16 channels... not possible for a common V4 firmware. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
k2z3k0 Posted October 16, 2017 Report Share Posted October 16, 2017 got it thanks for time bests Quote Link to comment Share on other sites More sharing options...
jjonas Posted October 21, 2017 Report Share Posted October 21, 2017 I tried the PATTERN page copy/paste in pre094. It seems that currently pressing COPY or PASTE copies or pastes all four patterns, instead of just the currently selected one. I'm not sure what the COPY+PASTE (pressing & holding COPY and then pressing PASTE) operation is doing. On the EDIT page the COPY+PASTE operation duplicates the content and length of the track (e.g. 16/128 to 32/128), but how does this translate into a pattern operation? One of the alternatives that would make sense is if pressing and releasing COPY or PASTE copies and pastes all patterns, and COPY+PASTE copies and pastes only the selected pattern. But when I press and hold COPY on the PATTERN page, the seq copies all patterns immediately. I would have expected that pressing and holding COPY doesn't do anything until I release the button, so that while pressing and holding COPY I can press PASTE as well if I want to activate the COPY+PASTE function. Or did I misunderstand something? Quote Link to comment Share on other sites More sharing options...
TK. Posted October 21, 2017 Author Report Share Posted October 21, 2017 There are two intended use cases: all patterns (which are showed by the PATTERN page) can be copied into a buffer with the COPY button. Then you can select other patterns, and PASTE the buffer into these slots. all patterns (which are showed by the PATTERN page) can be duplicated into the next pattern slots This was not possible before - it was required to go into the SAVE page and to store all 4 patterns into new slots Quote One of the alternatives that would make sense is if pressing and releasing COPY or PASTE copies and pastes all patterns is implemented this way Quote and COPY+PASTE copies and pastes only the selected pattern with this behaviour it wouldn't be possible to paste or duplicate all patterns at once anymore, but this is one of the major use cases. Quote I would have expected that pressing and holding COPY doesn't do anything until I release the button This is unusual and not required Quote so that while pressing and holding COPY I can press PASTE as well if I want to activate the COPY+PASTE function This isn't required, because for both use cases the currently visible patterns have to be copied into the buffer, hence this operation can be done when the COPY button is pressed. Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
v4 Posted October 27, 2017 Report Share Posted October 27, 2017 i've run into a few hard crashes on the latest pre2 beta while trying to 'save as' while the mb is running. can anyone reproduce this? it happens about 50% of the time it seems. midi output freezes as well as all notes hang. Quote Link to comment Share on other sites More sharing options...
k2z3k0 Posted October 27, 2017 Report Share Posted October 27, 2017 (edited) on my mb STM32F4 it doesnt crash(so far) but it does it kinda slow slugish kaz Edited October 27, 2017 by k2z3k0 Quote Link to comment Share on other sites More sharing options...
jjonas Posted October 27, 2017 Report Share Posted October 27, 2017 No crashes here either, but I too did notice the slow start of the 'Save as' process. I don't remember whether the seq was running at the time or not. Quote Link to comment Share on other sites More sharing options...
u-link Posted October 30, 2017 Report Share Posted October 30, 2017 Hi, could this be implemented: In the MIDI Router, an option to have "active track" as a IN selection. So when I select track 3, the data is automatically forwarded to a defined out and channel. The reason I am asking is that I have recently gotten a Keith McMillen K-Board, a little USB-Keyboard-pad-controller with backlit keys. To use that feature, you need to send it note data on channel 1 of its USB MIDI port Would be awesome to automatically see the programmed notes! I am sure there are more controllers with similar features available, I think there's one from NI etc. Also wanted to ask again if you are considering implementing the "Have Mixer Map on Encoders in Mute Mode" idea that I tossed in some months ago in this thread? Quote Link to comment Share on other sites More sharing options...
TK. Posted November 4, 2017 Author Report Share Posted November 4, 2017 On 27.10.2017 at 4:10 AM, v4 said: i've run into a few hard crashes on the latest pre2 beta while trying to 'save as' while the mb is running. can anyone reproduce this? it happens about 50% of the time it seems. midi output freezes as well as all notes hang. @v4: which core are you using? MBHP_CORE_STM32, MBHP_CORE_LPC17 or MBHP_CORE_STM32F4? @u-link: I added your request to the wish list. Instead of a MIDI router option, I will probably provide this as some kind of global "duplicate" option intended to satisfy your use case, so that additional special functions could be added later without taking limitations of the MIDI router into account. The "mixer map on encoders in mute mode" is also on the wish list now (together with your other proposals) - I've to consolidate this with other ideas around mixer map usage. This could become an optional mode which can be activated by people who know how to use it (otherwise it will confuse common users too much) Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
TK. Posted November 5, 2017 Author Report Share Posted November 5, 2017 A new version is available: MIDIboxSEQ V4.094 ~~~~~~~~~~~~~~~~~ o support for Antilog Frontpanel. The appr. HW configuration file can be found under hwcfg/antilog/MBSEQ_HW.V4 o enhanced COPY/PASTE/CLEAR functions for following pages: - PATTERN page: copy/paste/clears all patterns. Special function: by pressing COPY+PASTE the patterns will be pasted into the next slots - PARSEL page: copy/paste/clears the currently selected parameter layer only - TRGSEL page: copy/paste/clears the currently selected trigger layer only - INSSEL page: copy/paste/clears the currently selected instrument only (useful for drums: corresponding trigger any parameter layers are cleared) o improved ALL button behaviour o New worflow for PATTERN page: GP 1/2, 5/6, 9/10, 13/14 allow to select group as well especially interesting for Antilog Frontpanel: Selection buttons can be used for mutes) o New workflow for MUTE page: Whenever a track or parameter layer is unmuted, it will be automatically selected o EDIT page: improved handling for chord layers o moved some configuration settings which were previously part of the MBSEQ_HW.V4 file to the Options page, so that they can be changed without a file editor: - MIDI remote key (or CC) - Track Selection CC - MIDI OUT Runtime Status Optimisation - MENU button assignments o support for "Shadow Out", which will forward the MIDI events of the currently selected track to a specified MIDI port and channel (e.g. can be used to visualize played notes with an external device). Select the port/channel in the OPTIONS page. o Metronome page removed. Please configure the metronome function in the Options page. o Pattern banks can't be modified by default anymore, because they are typically assigned to group 1/2/3/4, changed bank assignments can confused users to much. If somebody still finds this feature useful: it can be enabled in the Options page @u-link your requested MIDI routing option is called "Shadow Out" and works independent from the MIDI router This version should also satisfy frequent requests for trigger/parameter/instrument copy/paste/clear functions Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
v4 Posted November 5, 2017 Report Share Posted November 5, 2017 On 11/4/2017 at 4:13 PM, TK. said: @v4: which core are you using? MBHP_CORE_STM32, MBHP_CORE_LPC17 or MBHP_CORE_STM32F4? @u-link: I added your request to the wish list. Instead of a MIDI router option, I will probably provide this as some kind of global "duplicate" option intended to satisfy your use case, so that additional special functions could be added later without taking limitations of the MIDI router into account. The "mixer map on encoders in mute mode" is also on the wish list now (together with your other proposals) - I've to consolidate this with other ideas around mixer map usage. This could become an optional mode which can be activated by people who know how to use it (otherwise it will confuse common users too much) Best Regards, Thorsten. apologies i was away from the studio for a week. STM32 is the core i'm using. Quote Link to comment Share on other sites More sharing options...
lobit Posted November 5, 2017 Report Share Posted November 5, 2017 Is there a way to have the pattern editing 'chase' the playback? for example on a longer pattern when playback passes step 16, flip to steps 17-32 and so on? Quote Link to comment Share on other sites More sharing options...
K-rAd Posted November 5, 2017 Report Share Posted November 5, 2017 pressing 'menu' and 'exit' at the same time will activate follow mode. Quote Link to comment Share on other sites More sharing options...
lobit Posted November 5, 2017 Report Share Posted November 5, 2017 great! thank you Quote Link to comment Share on other sites More sharing options...
K-rAd Posted November 5, 2017 Report Share Posted November 5, 2017 I am also experiencing the crash when doing a 'save as' of the session while seq is running. V4.091 STM32 Looking forward to checking out the new version. 1 Quote Link to comment Share on other sites More sharing options...
u-link Posted November 6, 2017 Report Share Posted November 6, 2017 5 hours ago, TK. said: your requested MIDI routing option is called "Shadow Out" and works independent from the MIDI router Amazing, it's working! I also really dig the name. "Shadow Out" - will make a track with that name. Thorsten, you are the man. Can anybody shed some light into the new option 15/25, "Sending Selected Track as CC to a DAW"? I quickly fiddled around with it a bit, but I don't get it to output anything. What are those sixteen CCs? The values set in each Parameter Layer? Or CC parameters to change settings of the track itself, like LFO Amount, MIDI Delay Feedback etc? Quote Link to comment Share on other sites More sharing options...
