MBHP_ETH, MBHP_SDCARD, SSM2044, SSM2164 PCB Bulk Order
#21
Posted 18 May 2010 - 20:16
#22
Posted 18 May 2010 - 22:00
Good news
#23
Posted 18 May 2010 - 22:18
I notice the ENC28J60 (for MBHP_ETH) isn't too widely available (i.e. not at all in my Australasia).
Bulk order? Or just add it to my next Mouser/Digikey order?
Thanks heaps Seppoman!
#25
Posted 18 May 2010 - 23:18
I would be very surprised if there's really no shop in Australia carrying the ENC, it is available virtually everywhere in Europe and the US. And it's a cheap item and you need only one per module, so shipping cost will probably kill any discounts in a bulk order. If you're not too much in a hurry and are planning to order at Digikey or Mouser in the next months, better get the ENC there, together with the MagJack - which is much harder to find than the ENC even in the US.
S
#26
Posted 19 May 2010 - 06:00
I will need another few days to solder all these card sockets ;).
You are soldering them by hand yourself!? Hope there were not too many ordered ;)
Thanks for the update.
sammichFM
MBSEQv4
HAWK-800EX
TR9090
x0xb0x
Trummaskin 90
GM5x5x5
#27
Posted 19 May 2010 - 06:38
well not entirely by hand (although that wouldn't take that much longer). I'm using a reflow oven, then remove any excess solder by hand and finally use an ultrasonic bath to remove any flux remains. There are 65 pieces ordered and I'm estimating two evenings of soldering, so it's not that bad ;)
S
#28
Posted 21 May 2010 - 11:04
i have 150 25mills QFP ICs to solder by hand.
If You planned to be in Italy let me know so You can give me a little help
Saluti
Antix
#29
Posted 31 May 2010 - 08:44
The SD sockets are already at my place, so I know what to do this weekend ;)
S
#30
Posted 31 May 2010 - 10:02
Any Aussies (and Kiwis) needing an ENC28J60 source can piggyback onto my next Mouser/Digikey order.
Maybe I should just get all the parts for the MBHP_ETH module in bulk... some of the other parts would be hard to find here.
Does anyone already have a BOM for Mouser?
Buy Wilba a Beer Disclaimer: buying Wilba a beer gets you absolutely nothing in return likesuchas sammichSID kit order queue jumping, purchase of SIDs and MIDIbox troubleshooting assistance.
#31
Posted 31 May 2010 - 11:24
This is the one I've put together, haven't ordered yet - I'll probably put it in with parts for a 16x16 BLM. Might be best if you check it, in particular I think I wasn't sure of the Magjack.
Ethernet IC 579-ENC28J60/SP 1 $4.90 $4.90
magjack? 523-RJHSE-5381 1 $1.58 $1.58
25mhz crystal 695-HC49US-25-U 1 $0.78 $0.78
ceramic cap 18pF 140-50N2-180J-RC 2 $0.10 $0.19
ceramic cap .01uF 140-50Z5-103M-RC 2 $0.14 $0.27
ceramic cap .1uF 140-50U5-104M-RC 3 $0.30 $0.89
tantal cap 10uF 80-T351E106M16AT 1 $0.70 $0.70
electrolytic 100uF 140-LLRL16V100-RC 1 $0.46 $0.46
2.32kohm metal film 1% ¼ watt 271-2.32K-RC 1 $0.18 $0.18
49.9ohm metal film 1% ¼ watt 271-49.9-RC 4 $0.18 $0.70
220ohm metal film 1% ¼ watt 271-220-RC 2 $0.18 $0.35
ferrit bead 10uH 434-22-100 1 $0.27 $0.27
2x5 header 517-30310-6002 1 $0.55 $0.55
#32
Posted 01 June 2010 - 02:31
I'll be in! Cheers! Maybe one day I'll have an actual use for MB_ETH
#33
Posted 01 June 2010 - 09:14
That one is completely wrong. It doesn't even have integrated magnetics ("transformer"). It's not sufficient that it has a hole where you can stick a LAN cable in ;)
The "official ones" are made by Bel Stewart (Belfuse) and have the Word MagJack embossed. And even Bel Stewart makes hundreds of different models, some are suitable, most aren't. They have different footprints, pin configurations, different setups and properties of the transformer part etc.
Part numbers:
SI-60062-F
SI-60024-F
SI-40141-F
There are a few other Bel Stewart parts available e.g. from Digikey that mainly differ in LED colors. I will make a list of more suitable part numbers tonight. It looks like Mouser doesn't sell Bel Stewart parts at all, so better check out Digikey for the other parts, too.
There's dozens of manufacturers making literally thousands of different varieties of these "MagJacks". E.g. I'm using a Tyco part for another project, some people are using PulseJack parts with ENCs on the net. But at least the Tyco has a different pinout. Maybe there is even some part from a different manufacturer that has a matching pinout etc, but finding these would involve comparing thousands of datasheets, so better stick with the Bel Stewart parts.
S
#34
Posted 03 June 2010 - 00:37
Looking at the datasheets, I've found at least two models that are in stock at Digikey that are suitable. Part numbers are SI-60001-F and SI-60005-F. Both are reasonably priced and differ only in LED colors. If you wanna build your ETH modules before end of year, I'd suggest not to wait too long to order these connectors as it looks like supply is not too dependable right now and the manufacturer has quite long lead times.
I'll try to find you some more part numbers in the next days (also I hope there might be a few compatible parts from other manufacturers).
S
#35
Posted 08 June 2010 - 10:50
The PCBs finally arrived, and I've even already completed soldering all the SD sockets. I'm only waiting for a final Go! from TK who is about to test the ETH and SDCARD module. So the PCBs will start shipping within the next few days. Padded envelopes are ready
BTW I've got a few spares of the ETH and SDCARD module available, and there's about 50 spares each of both SSM PCBs.
The ETH/SDCARD spare PCBs are meant to bridge the gap until SmashTV will eventually start offering these, so please only order these if you know you won't just put them on the shelf for years but you will use them in the next months. I won't sell more than one of each per person if you don't come up with a good explanation why you would need 10 ETHs immediately ;)
S
#36
Posted 08 June 2010 - 11:24
Jubilee Post No. 1000, hurray
S
Congratulations for the 1000 posts!
sammichFM
MBSEQv4
HAWK-800EX
TR9090
x0xb0x
Trummaskin 90
GM5x5x5
#37
Posted 08 June 2010 - 17:00
I don't even know why I would need even 1 ETH ever... ;)
Congratulations on 1000 posts!
#38
Posted 17 June 2010 - 23:12
S
#39
Posted 18 June 2010 - 11:37
A little update again - in the meantime, TK has built and tested both new modules and everything's fine, so I can start shipping PCBs now
bad news is that I'm having a very busy week at work, so I didn't manage to do any packing and labeling yet. I'm hoping for some time on the weekend though, so I promise I'll hit the post office next week
S
Good! My SSM2044 are starting to get bored...
sammichFM
MBSEQv4
HAWK-800EX
TR9090
x0xb0x
Trummaskin 90
GM5x5x5
#40
Posted 18 June 2010 - 13:46
My SSM2044s are sleeping at Milano custom's offices.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
