Ponoko front panel for Wilba's control surface pcb
findbuddha
By findbuddha in MIDIbox BLM,
Can someone please give a quick look over this svg? Any tips would be appreciated. Mostly it is a direct conversion of wilba's 17" dxf. I have removed the 'extra' ring around the mounting holes, changed the lcd windows to a simple cutout, and widened the vertical spacing of the lcd mounting holes to match the optrex displays I'm using. I plan to double up the engraving layer before submitting to ponoko. File was composed in Inkscape. Thanks :) panel.zip
  • 30 replies
