Sorry if my questtion is stupid,
but i read http://www.midibox.org/dokuwiki/doku.php?id=windows_toolchain_quickstart ,search forum and google but...
wen i try to compile my project, this happens:
make: *** C:\MIOS\Mios_Base: Invalid request code. Stop.
What is wrong in Mios_Base folder???
PS: MIOS_PATH and MIOS_BIN_PATH is ok
SDCC ok
MSYS ok
GPUtils ok
PATH ok (C:\MIOS;C:\MSYS\1.0\bin;C:\Arquivos de programas\gputils\bin;C:\Arquivos de programas\SDCC\bin)
my folder project: c:\mios\vmx200
Thanks!
That sounds like there's some stuff missing or can't be found.
Since it's fairly hard to guess what that may be please do the following:
1) Open a command prompt like you usually do, and do what you do to get to the point where you try to make the app
2) Type "set mios" and post the results here
3) Type "make --version" and post the results here
Then we'll take it from there :)
Posted (edited)
Microsoft Windows XP [versão 5.1.2600]
© Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Aliã>cd c:\mios\vmx200
C:\MIOS\vmx200>make
C:\MIOS\vmx200>set mios
MIOS_BIN_PATH=C:\MIOS\Mios_Base\bin
MIOS_PATH=C:\MIOS\Mios_Base
C:\MIOS\vmx200>make --version
GNU Make 3.81
Copyright © 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for i686-pc-msys
C:\MIOS\vmx200>
strange...
thanks again.
Edited:
I dont have mingw installed, i need it?? where i can find? and what version?
because in wiki mingw is installed, look:
C:\MSYS\1.0\bin;C:\Program Files\gputils\bin;C:\Program Files\SDCC\bin;C:\MinGW\bin;C:\Program[bLABLABLA]
I reinstall all again and reupload mios_base_v1_1...
I see some strange stuff in post install of my sys, but is about mingw, and i dont have it, but...
This is a post install process that will try to normalize between
your MinGW install if any as well as your previous MSYS installs
if any. I don't have any traps as aborts will not hurt anything.
Do you wish to continue with the post install? [yn ] y
Do you have MinGW installed? [yn ] n
When you install MinGW I suggest you install it to C:/mingw
(replace C: with the drive of your choice). Then create an
/etc/fstab file with a line that has a value similar to:
C:/mingw /mingw
Press ENTER to continue
Normalizing your MSYS environment.
You have script /bin/awk
You have script /bin/cmd
You have script /bin/echo
You have script /bin/egrep
You have script /bin/fgrep
You have script /bin/printf
You have script /bin/pwd
MinGW-1.1 has a version of make.exe within it's bin/ directory.
Please be sure to rename this file to mingw32-make.exe once youve
echo installed MinGW-1.1 because it\s very deficient in function.
Press ENTER to continue.
Edited by Aliã Bianco
  • 4 months later...
Hey!
I have a MIDIbox SID synth, working.
How can i configure the buttons, encoders and the lcd display?
I have 8 rotary encoder+6 button and a 4X20 lcd display.
The PIC is a 18F452. "midibox_sid_v1_7303e" is ok.
Which file and how? How to reprogrammed and burn the device with the new firmware?
Thanks!
Best:)
Relevant for MBSID V1 (not MBSID V2!):
- setup_*.asm (the setup file you are using)
- src/mios_tables.inc
- src/cs_menu_io_tables.inc
- src/cs_menu_enc_table.inc
There are some comments in these files which you have to read to understand the configuration options.
Once the firmware has been recompiled, just upload the resulting .hex file via MIDI like you did before.
Posted (edited)
Hallo Klose!
Danke für die Beihilfe!
Das wird meine erste midibox projekt:-)
Beste Grüsse!;-)
Edited by nILS
Don't fullquote posts with pics unless you actually respond to them, please.
