Aliã Bianco Posted August 5, 2010 Report Share Posted August 5, 2010 Hi guys, im using mplab to try compile my project, but wen i compile the project, i get an error. here is the cause: This explanation i found in readme of mplab c18. Referencing a variable declared 'extern' with an initializer causes an internal failure. For example: extern int x = 5; void main (void) { x++; } generates an internal error. The workaround is to remove the 'extern' storage class specification or remove the initializer. what should i do??? kill me? mysys dont work, mplab dont work... i dont have more ideas. thanks Quote Link to comment Share on other sites More sharing options...
Duggle Posted August 5, 2010 Report Share Posted August 5, 2010 Hi guys, im using mplab to try compile my project, but wen i compile the project, i get an error. here is the cause: This explanation i found in readme of mplab c18. Referencing a variable declared 'extern' with an initializer causes an internal failure. For example: extern int x = 5; void main (void) { x++; } generates an internal error. The workaround is to remove the 'extern' storage class specification or remove the initializer. what should i do??? kill me? mysys dont work, mplab dont work... i dont have more ideas. thanks My guess is to follow the suggestion: 1) define the variable in the local module ie: int x=5; void main (void) { x++; } OR 2) initialise it in the module where it is defined ie. int x=5; AND declare it (but dont initialise it) where it is used (locally) so your code would be: extern int x ; void main (void) { x++; } Quote Link to comment Share on other sites More sharing options...
