Midi message sender channel !
alexglvr
Yes. The MIDI Channel is the lower nibble of evnt0. Hence you can do the following to get the channel:
// This function is called by MIOS when a complete MIDI event has been received
void MPROC_NotifyReceivedEvnt(unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam
unsigned char channel = evnt0 & 0x0f;
// do something
}[/code]
Thank you for your Help!
I read several documentation on Midi but things are still a bit confused...
Each midi component is attributed a midi channel !
But, this channel is only usefull for midi in, isn't it?
But for example, for a midi keyboard with a midi-in and a midi-out, how does it work?
If it is attributed channel 1, it sends midi orders on channel 1 and receive order on channel 1?
In fact I am completely lost... lol
Alex
Yes.
No. For any receiver it's important to know where the message is coming from. For any sender it's important to show where the message is coming from.
Ok !
So if I want to build a midibox that receives orders from two different pedalboard, I see two possibilities:
1- The two pedalboards plugged on a midi merger, and the output of the midi merger to the MIDIBOX
2- Make a two port midibox. In this case, it could even use a single channel isn't it?
