Unfortunately that's the best camera I can come up with immediately. I'll try to get some better photos. I think it's the lighting. I have a lamp right above my workspace. It's great for seeing what I'm working on but maybe not as much for Photography...
I apologize for my confusion about PIC > Opl3:J2 connections. I disconnected it for these readings.
I had measured them against Opl3:J3 ground. I listed those voltages because with that being the Only connection the Opl3 module had to anything, the LED was still lighting.
Here's the answers to your questions.
1) With everything disconnected, what voltage do you read from IC1:12(Vss) to IC1:11(Vdd) on the core module? : 5V
2) When you connect Core:J1 to OPL3:J1 only - what voltage do you read from IC1:12(Vss) to IC1:1(Vdd) on the OPL board? : I connected Core:J2 to Opl3:J1 IC1:12 to IC1:1 on the Opl3 Module and got 5V.
I was hesitant to hook Core:J1 (9V) to the 5V rail without doublechecking with you.
3) Does the LED light up with just the Core:J2 > OPL:J1 connection? : Yes
4) With no wires connected anywhere - What's the resistance between the following pin pairs on the OPL module:
IC3:4 and IC1:12 24M Ohm
IC3:4 and IC1:1 24M Ohm
IC3:11 and IC1:12 7M Ohm
IC3:11 and IC1: 7.1M Ohm
J3:V+ and J3:Gnd 35M Ohm
J3:V- and J3:Gnd 32M Ohm
J3:V+ and J3:V- 16M Ohm
3) "I haven't attached the pull-up resistor for the CAN Bus." - the diode isn't there either? : No
