for 1 yac i need to solder ...
yodabe
hi all
for 1 yac i need to solder other components ?
original link
Uploaded with ImageShack.us
tested the module and no sound
tested with mbfm_interconnection_test_v2 the connection its ok
tested with mbfm_testtone_v1c no sound in out 1 or 2
i got a popping noise sound when turn on the mbfm
best regards
Edited by nILS
resized the pic and attached it to the post
Link to comment
Share on other sites
That's all the parts you need (if the components on the bottom side of the board are soldered correctly and there's a jumper wire under IC3).
* Got a pic of the underside?
* Are the voltages ok (especially the bipolar supply voltage for the OPAMPs)?
Link to comment
erm...dont get me wrong but that soldering looks really aweful and you got several bridges at the smd chips and all over the place.That´s very likely the reason that it is not working. I see bridges at pin 8/9 and 13/14 of the OPL. The Chips look like they would "stand" on solder.
Then you got a bridge in front of the nr. 1 pin of the OPL between the third and fourth trace...and so on..
What iron did u use? Small tip and regulated is highly recommended especially when dealing with SMD parts. Its not only that
you get bad and bulky joints but you "burn" the chips using an unregulated iron with a big tip.
What you can do now is "cleaning" the PCB. That means that you get yourself some solder wick and desolder the SMD parts (with a decent iron!) and resolder the obvious bridges. Do that carefully. Dont heat the SMD parts for too long and with to much power. They will fry if they havent already.
I could imagine you already broke the parts but just try it.
Watch this to get an impression how to solder SMD.
http://store.curiousinventor.com/guides/Surface_Mount_Soldering/101/
Edited by phunk
Link to comment
i use an ersa 3cs/331 30w and 1.5mm tips
the chip are not burned i desolded it very carefully it does not have to heat only tepid
check my new pic with light back the board
thx for your help
Link to comment
Aren't you missing some components south of IC6? Best solution would be to just solder the missing parts, i think - all done :thumbsup: that way you will also be ready for an extra YAC if you find one at some point. It's not like it will be very expensive or anything :tongue:
Link to comment
The missing components (C14, C19, C13, R13, R10, R12, R15, C25, C26, C29, R11, R14, C33, R20, R21, R22, R23, C34, R3, C11, C22, C21, C12, C30) are only relevant for the second YAC (see http://ucapps.de/mbhp_opl3.html). Leaving them out will not cause any problems.
Make sure to check for bridges further away from the SMD chips as well - better to be on the safe side :)
If you're positive that you don't have any bridges, remove the opamps and see if you get an audio signal @ IC3:10 and IC3:14. That'll help to tell us if the problem occurs before or after the opamps.
Link to comment
Read
I had problems with the YAC. I am still not sure if it was the chips I got or my Surface mount soldering. Those little bastards are finicky. I was super meticulous with the second set I got and Lo and Behold! I Haz FM!
I do know that I had problems with my GM5 and upon closer inspection it looked like it probably could have done with a more thorough soldering job. Unfortunately, when I went to pull him off, a couple of his legs went bye bye. :bye: Poor little guy never had a chance.
Luckily the YACs seem a lot sturdier.
Check pins 21 and 22 on the YMF with a headphones and a resistor or something like that to see if your getting audio out of it.
Link to comment
get this from ic3 pin 10
and this on ic3 pin 14
thx
all module
Edited by yodabe
Link to comment
Those are digital pins - why would you "listen" to what comes out of them? There's no audio before the YACs.
By default all unselected pins are 0V
Hmm.
1) Remove the LCD for testing (as it shares pins with the OPL3)
2) Check for shorts on the core>opl3 connection
3) Recheck the wiring (http://ucapps.de/mbhp/mbhp_opl3_interconnections.pdf)
4) Shorten the cable between core and opl module
Link to comment
Hmm.
tested the same
checked no shorts and tested with other core module the same !!!
3) Recheck the wiring (http://ucapps.de/mbh...connections.pdf)
checked and rechecked no error
not tested thats possible is only the cable in fault ?
other test
try other pic the first is a 18f457 try on 18f4685 the same
tested with no eeprom on core board the same
tested only the core the same error on d0 d1 d2 d3
thx
Link to comment
re
i try new upload mios 1.9g and mbfm 1.1d modified asm for my encoders en recompiled for 18f4685
not work 4.77v on d0-d3
try lcd in 4bit mode + pull up resistor for the can bus
not work too
im lost !
IN readme.txt :
The SID pins are mapped to following keys:
C : Pin J2_1:RS = 5V
C#: Pin J2_1:A0 = 5V
D : Pin J2_1:A1 = 5V
D#: Pin J2_1:WR = 5V
E : Pin J2_1:D0 = 5V
F : Pin J2_1:D1 = 5V
F#: Pin J2_2:D2 = 5V
G : Pin J2_2:D3 = 5V
G#: Pin J2_2:D4 = 5V
A : Pin J2_2:D5 = 5V
A#: Pin J2_2:D6 = 5V
B : Pin J2_2:D7 = 5V
the sid ? not a sid is opl module
are you 100% sure if the d0-d3 is setup to 0v in interconection test ?
maybe anybody test in your mdfm if you have 4.7v on d0-d3 ?
on my all core module is 4.7v to d0-d3 !
thx
Link to comment
the interconnection test isn't prepared for PIC18F4685; you also need a special modification in the MBFM firmware to get access to the OPL3 module.
As I'm planning to upgrade my own MBFM to PIC18F4685 soon, I will be able to adapt the applications so that you are able to continue.
Link to comment
its very cool TK thx
but i have 18f452 with mbfm on (my first test)
i retest the interconnection with this and feedback
thx
best regards
Link to comment
Guest
Reply to this topic...
