sammichFM
#41
Posted 26 May 2011 - 07:51
http://sound.westhos...er-supplies.htm for an overview
Coils are available at Reichelt "Flachtransformatoren" for 5-8€ a piece.
Linear PSUs are difficult to get (or expensive, 80€+), because they are considered special nowadays, switching PSUs normally do the job more efficiently (albeit for a few audio audio people who hear ´em :-)).
#42
Posted 26 May 2011 - 08:16
@Hawkeye: You have a great DIY-attitude :-) But with my experience, I will likely blow the sFM into pieces instead of powering her. Therefore I will stick with my switch-mode PSU first and see if induced noise will occur. If so, I'll try the Pollin PSU and report on the forum.
Edited by kristal=, 26 May 2011 - 08:17.
#43
Posted 26 May 2011 - 12:33
#44
Posted 26 May 2011 - 14:09
Buy Wilba a Beer Disclaimer: buying Wilba a beer gets you absolutely nothing in return likesuchas sammichSID kit order queue jumping, purchase of SIDs and MIDIbox troubleshooting assistance.
#45
Posted 26 May 2011 - 16:01
Regarding a linear psu, you can also build them yourself (but be careful with the high voltages) for low credits.
That's usually my favorite option, though for the Sammich I didn't want a huge power brick as I can't build my own PSUs smaller than a commercial solution. Plus, there's that epic thread about adding circuit protection stuff and all that so I figured the Sammich might be best served via a $20 regulated power brick someone else built.
#46
Posted 01 June 2011 - 13:21
a|x
#47
Posted 03 June 2011 - 16:07
Maybe some kaffeSEQ too?
Edited by pulsn, 03 June 2011 - 16:08.
#48
Posted 07 June 2011 - 00:49
here a link for a PSU that works fine with both sammichSID and FM
VOLTCRAFT® USPS-600
#49
Posted 07 June 2011 - 10:30
You'll have to log in with your forum's username and password first. Go and tryI can not edit in the wiki!
#50
Posted 29 June 2011 - 12:30
#51
Posted 29 June 2011 - 13:53
The trade-off is that what you really end up with is a bunch of pulses on the DC signal that look like a certain voltage overall (say 12V). Think of it as a somewhat ugly high frequency square-wave of sorts. The problem here is that the high frequency noise this creates cannot be totally filtered out without using capacitors that are built to dampen HF noise (such as tantalum). These can be both expensive, some say dangerous (I tend to disagree), and a bit of a black art. From what I have read, ceramics can reduce HF noise but this comes at a price. So you have to end up using various different types of caps. In the end, capacitors are not perfect and you may need to use quite a few to remove the noise, or may not be able to remove all of it regardless.
Linear PSUs do not have this problem as the noise they generate is typically easier to filter out and it's usually HF (though I think if you have HF noise coming from the AC side, you may see some of that on the DC - not entirely sure though).
All that said, if you're not hearing the noise, it could be too high pitched for your ears - either because you went to too many concerts without earplugs
TL;DR If you can't hear it, it's probably ok.
#52
Posted 29 June 2011 - 15:47
#53
Posted 29 June 2011 - 15:56
If you do some searching on the forums, you'll likely find a few flamewars over whether or not switch-mode is really that bad or if it's Satan himself being resurrected through audio. The best advice I can give is do some research (including the audio tests like you are doing) and form your own opinion
Switchmode tends to be discussed more in a practical sense for the larger projects that need a series of voltages, such as the MB-6582 or when using SSM filters and other fun things. In those cases, switchmode tends to offer multiple voltages in smaller packages than a linear supply and with a lot less heat. Sort of an aside but I thought I'd mention it anyway.
#54
Posted 29 June 2011 - 21:54
#55
Posted 19 July 2011 - 11:59
a|x
#56
Posted 28 July 2011 - 13:16
a|x
#57
Posted 28 July 2011 - 13:19
#58
Posted 28 July 2011 - 23:33
Incidentally, I had no problem at all finding a power-supply that worked. I've tried two different cheapo 9v DC wall-warts, and both have worked fine. I'll probable settle on the £7 one I got from Farnell, as I bought a matching set of 4, to power this box, and my 3x Shruthi-1 synths.
a|x
Edited by toneburst, 28 July 2011 - 23:36.
#59
Posted 28 July 2011 - 23:49
#60
Posted 07 August 2011 - 12:55
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
