John_W._Couvillon Posted July 5, 2011 Report Share Posted July 5, 2011 Anyone, I am looking for a 0 ohm shorting bridge to use on a DOUT card in place of the ULN2803 driver chip. Would appreciate help finding same if anyone knows a source. Thanks, Johnc Quote Link to comment Share on other sites More sharing options...
findbuddha Posted July 6, 2011 Report Share Posted July 6, 2011 Some wire? Sorry if this is a noob answer :) Quote Link to comment Share on other sites More sharing options...
sparx Posted July 6, 2011 Report Share Posted July 6, 2011 Some wire? Only a solution if its a permanent fixture. But 0 ohm resistors are basically wire so not such a daft answer... You may have to search high and low for such a dip network, what about using 8 x DIP switches? Easily obtainable and removable if required? S Quote Link to comment Share on other sites More sharing options...
gomiboy99 Posted July 6, 2011 Report Share Posted July 6, 2011 (edited) This is the kind of thing you need http://uk.farnell.com/harwin/d6216-01/header-dil-16way/dp/176362 just solder wires across the pins to make the bridges. Should be available from Farnell's US centre in Newark. Hope this helps Tim.. Edited July 6, 2011 by gomiboy99 Quote Link to comment Share on other sites More sharing options...
