SexyBeast Posted September 12, 2003 Posted September 12, 2003 Hi,this week I've tested my 18F452 core module with MIOS 1.3 and a DIN module with one encoder attached to it. I used the test program "enc_example3_v1_3.zip". Thing is: when i turn the encoder knob clockwise, the value decreases, when I turn it anticlockwise it increases. Normally it should be vice versa...First I thought I had the encoder wires attached the wrong way but this doesn't seem to be the case.Any ideas?regards, SB
TK. Posted September 12, 2003 Posted September 12, 2003 The pinning of your encoder could be different. If you don't own a datasheet, just try all possible combinations.Best Regards, Thorsten.
