Hi All,
I need something of a small routine (for eg a call procedure )which I can insert just about anywhere in the code (regarding MIOS8 projects) The routine should be capable to output the variable or register that you want to debug and to output these either thru the MIDI out ports or on the LCD (but prefer the MIDI port).
I would appreciate if some one has something like this available. Generally, this can be of course quite useful for all the MIDIBOX forum community.
Thanks
SMC
MIOS8: just generate (valid) MIDI events to output the variable value, e.g.
MIOS_MIDI_TxBufferPut(0xc0); // program change allows to send one additional 7bit byte
MIOS_MIDI_TxBufferPut(the_variable & 0x7f);
[/code] or:
[code]
MIOS_MIDI_TxBufferPut(0xc0 | ((the_variable & 0x80) ? 1 : 0)); // program change + MSB of variable
Alternatively you could try the debug_msg module which is located under modules/debug_msg
See also http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fmodules%2Fdebug_msg%2FREADME.txt
It sends text strings to the MIOS terminal
MIOS32 (to complete this posting):
use MIOS32_MIDI_SendDebugMessage to generate debug messages with a printf like parameter list
See also http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Ftutorials%2F003_debug_messages%2F
Guest
Reply to this topic...
