boops Posted September 18, 2011 Posted September 18, 2011 Hello, i have built a midi Cv with a NG out @ TK ...i ve found that the option merger didnt save in a patch,i have to put"on" each time..is it normal or a miss in the soft? thanks
sneakthief Posted September 18, 2011 Posted September 18, 2011 Same thing happens to me - I'll save a patch with the merger ON and the next time I turn on the MIDIbox CV, the menu says that the merger is on but it's not (unless you select merger OFF then select ON again)
TK. Posted September 28, 2011 Posted September 28, 2011 There is a conceptional problem with this option. If the merger setting would be restored on each patch change, you would have to adapt all your patches whenever you've changed your MIDI setup. It would be better to handle it separately like a "global option" (e.g. stored in internal EEPROM independent from the patch), but the application isn't prepared for this. I'm still unsure about the best solution. Best Regards, Thorsten.
