modulable SEQ and BLM (separate)
Lamouette
HI all,
I have a question, i recently add my name on the SEQV4 bulk order, and after i will build it, i would to built a BLM, but i have a question :
Do you think i's possible to separate the BLM like a plug: for exemple when you want to use your SEQV4 without BLM you just unplug a box with the BLM and you could use the SEV4 "alone", and if you want you "re-plug" the BLM and you could use like normal SEQV4 and BLM.
I'm sorry for my bad english, but i hope you will understand my question !
Thanks and bye all !
Edited by Lamouette
It is possible to separate the BLM from MBSEQ with a plug, I'm doing this as well! :)
See the socket at the right side of the rear panel:
Here the schematic for the 8-pin connector:
http://www.ucapps.de/midibox_blm/blm_connector_mbseq.pdf
The BLM can be connected/disconnected during runtime and will be automatically detected, no need to reboot the sequencer.
