Using a RTCC to set the SD card file system timestamp
Duggle
Hi All,
I've connected a RTCC (real time clock calendar) chip MCP79410 to IIC bus STM core32. I'm able to set it and read it o.k
It keeps time when the core is not powered (by way of supercap).
Question is: Is there a way to use this time with SDcard so that files created have the correct timestamp?
Ive been playing with the SD card Tool application to see how file accesses are done.
thanks
Hey, good to hear! Could you tell us how exactly you connected the RTCC, and what you did to set it properly? Does it account for leap years and daylight saving time changes automatically? For how long does it keep the correct time / date if not powered up? Hehe, too many questions...
Edit: well, never mind, it's all in the device's documentation which can be found here.
Thanks, ilmenator
Edited by ilmenator
Cool, thanks! Have you got an estimation of how long the supercap will hold enough charge to keep the RTCC running? Which model are you using? The original design suggests the use of a battery.
I'm using the device without unique ID feature MPC79410.
The data sheet says 700nA to power in standby (Vbat=1.8V) so I think a Lithium coin cell is the best for most use cases.
I calculate the 0.9F supercap will keep the clock running for only 36days.
A coin cell may easily have 100mAhrs that's >100,000 hrs, well over 10 years.
Here's some code to access this device: (at least the RTCC features)
MCP79410.h
#ifdef __cplusplus
extern "C" {
#endif
extern void RTC_init();
extern char* RTC_GetTimeString();  				//read time "hh:mm,dd-mm-yyyy"
extern char IsTimeStrFormat(char * ts); 		//validate TimeString format
extern void RTC_SetFromTimeString(char* ts);	//set time "hh:mm,dd-mm-yyyy"
extern void RTC_PutForward1Hour(); //put time forward an hour (i.e -> Daylight Savings)
extern void RTC_PutBack1Hour();    //put time back an hour (i.e-> NON Daylight Savings)
extern char RTC_IsSet();			//has the RTCC been set?
#ifdef __cplusplus
#endif
MCP79410.c
#include <mios32.h>
#include <string.h>
#include <time.h>
#include "MCP79410.h"
#define I2CADDR  0x6F
#define VbatEnableReg 3
#define VBATEN 3
#define ST  7
#define reg_seconds 0
#define msk_seconds 0x7F
#define reg_minutes 1
#define reg_hours 2
#define msk_hours 0x3F
#define reg_day 3
#define msk_day 0x07
#define reg_date 4
#define reg_month 5
#define msk_month 0x1F
#define reg_year 6
#define reg_control 0x07
#define SQWE  6
#define OUT 7
#define SRAM_START 0x20
void RTC_WrReg(u8 r,u8 d){
 u8 sub[2];
 sub[0]=r;
 sub[1]=d;
s32 x=MIOS32_IIC_Transfer(0,IIC_Write,I2CADDR<<1,sub,2);
 x=MIOS32_IIC_TransferWait(0);
u8 RTC_RdReg(u8 r){
 u8 d;
 d=r;
 s32 x=MIOS32_IIC_Transfer(0,IIC_Write,I2CADDR<<1,&d,1);
 x=MIOS32_IIC_Transfer(0,IIC_Read,I2CADDR<<1,&d,1);
 x= MIOS32_IIC_TransferWait(0);
 return d;
u8 Int2BCD(int x){   //return integer as two decimal digits
  char low=x%10;
  char hi=(x/10)<<4;
  return hi|low;
int BCD2Int(u8 bcd){  //Convert two BCD digits to Integer
  int h=10*(bcd>>4);
  return h+(bcd&0x0f);
void RTC_init(){
  char regval;
  regval=RTC_RdReg(VbatEnableReg);  //read dont change other bitfields
  regval|=(1<<VBATEN);              //enable backup supply
  RTC_WrReg(VbatEnableReg,regval);
  regval=RTC_RdReg(reg_seconds);  //read dont change other bitfields
  regval|=(1<<ST);                //start the osc
  RTC_WrReg(reg_seconds,regval);
  RTC_WrReg(reg_control,((1<<SQWE)|(1<<OUT)));  //enable squarewave 1Hz on MF Pin. Requires pullup on MFP
char* RTC_GetTimeString(){  //return timestr
  static char s[24];
  char secs,mins,hrs,date,mth,yr;
  secs=RTC_RdReg(reg_seconds);
  secs&=msk_seconds;
  mins=RTC_RdReg(reg_minutes);
  hrs=RTC_RdReg(reg_hours);
  hrs&=msk_hours;
  date=RTC_RdReg(reg_date);
  mth=RTC_RdReg(reg_month);
  mth&=msk_month;
  yr=RTC_RdReg(reg_year);
  sprintf(s,"%02X:%02X,%02X-%02X-20%02X",hrs,mins,date,mth,yr); //TimeStr
  return s;
char IsTimeStrFormat(char * ts){   //"hh:mm,dd-mm-yyyy"
  char result=0;
  if (strlen(ts)==16)
		result=1;
  else{
		MIOS32_MIDI_SendDebugMessage("TimeStr format:\"hh:mm,dd-mm-yyyy\" bad length-%d-",strlen(ts));
		return 0;
  if ((ts[2]==':')&&(ts[5]==',')&&(ts[8]=='-')&&(ts[11]=='-'))
   	result=1;
  else{
		MIOS32_MIDI_SendDebugMessage("TimeStr format:\"hh:mm,dd-mm-yyyy\" bad format");
		return 0;
  return result;
void TimeStr2tm(struct tm* T, char* t){      //fill in struct tm with an input timestr
    T->tm_hour=(t[0]-0x30)*10+(t[1]-0x30);
    T->tm_min= (t[3]-0x30)*10+(t[4]-0x30);
    T->tm_sec=0;
    T->tm_mday= (t[6]-0x30)*10+(t[7]-0x30);
    T->tm_mon= (t[9]-0x30)*10+(t[10]-0x30)-1; 	//from 0
    T->tm_year= 100+(t[14]-0x30)*10+(t[15]-0x30);
    T->tm_wday=0;
    T->tm_isdst=0;
char RTC_IsSet(){
  char yr;
  return (yr>0x10);        //unset RTC has year==01
void RTC_PutForward1Hour(){     	//put time forward an hour (i.e -> Daylight Savings)
char hrs=RTC_RdReg(reg_hours);
char x=hrs;
 	x&=~msk_hours;  //clear hours field
 	hrs&=msk_hours;  //clear non hours field(s)
     hrs=BCD2Int(hrs);
 	++hrs;       	//inc hours as integer
     if (hrs==24) hrs=0;
     hrs=Int2BCD(hrs);//store as BCD
 	hrs|=x;          //set control bits
 	RTC_WrReg(reg_hours,hrs);
void RTC_PutBack1Hour(){            //put time back an hour (i.e-> NON Daylight Savings)
u8   hrs=RTC_RdReg(reg_hours);
u8   x=hrs;
     hrs=BCD2Int(hrs);
     if (hrs==0)
		hrs=23;
     else
        --hrs;       	//dec hours
void RTC_SetTime(struct tm* T){
  char x,mins,hrs,date,mth,yr;
  mins=Int2BCD(T->tm_min);           	//load and convert to BCD
  hrs=Int2BCD(T->tm_hour);
  date=Int2BCD(T->tm_mday);
  mth=Int2BCD(T->tm_mon+1);         	//months start from 0
  yr=Int2BCD(T->tm_year-100);     	//year counted from 1900
                                    //dont worry about seconds
  RTC_WrReg(reg_minutes,mins);
  x=RTC_RdReg(reg_hours); 	//read all
  x&=~msk_hours;              //clear data bitfields
  RTC_WrReg(reg_date,date);
  x=RTC_RdReg(reg_month);
  x&=~msk_month;
  mth|=x;
  RTC_WrReg(reg_month,mth);
  RTC_WrReg(reg_year,yr);
void RTC_SetFromTimeString(char* ts){ //"hh:mm,dd-mm-yyyy"
	struct tm T;
	TimeStr2tm(&T,ts);
	RTC_SetTime(&T);
Nice! :)
Under modules/fatfs/src/diskio.c you will find the get_fattime() function which is currently not implemented:
DWORD get_fattime(void)
/* 31-25: Year(0-127 org.1980), 24-21: Month(1-12), 20-16: Day(1-31) */
/* 15-11: Hour(0-23), 10-5: Minute(0-59), 4-0: Second(0-29 *2) */
return 0;
[/code]
I could declare it as "weak", this would allow you to implement an alternative version in your driver (a weak function will be replaced by your implementation if it's linked into the project)
Hi TK,
I've experimented by modifying the header declaration to:
DWORD get_fattime (void) __attribute__((weak));
I'm confused however, as the declaration appears in ff.h (not diskio.h) and your implementation is defined in diskio.c
Anyhow, I'm finding that your implementation is getting executed, not mine, which is implemented in my app.cpp
I'm sure what I need to do here? Did I get the declaration syntax right?
thanks.
The declarations and definitions in the repo need to be appropriately modified for this weak override business to work. The only way I can seem to get it to work is to comment out TK's implementation of get_fattime().
Anyhow it's working fine!
This is in my app.cpp
extern "C" DWORD get_fattime(void)
  return RTC_GetFatTime();
and this is added to the RTCC driver routines listed earlier:
 DWORD RTC_GetFatTime()
	DWORD FatTime=0;
  	secs&=msk_seconds;
  	hrs&=msk_hours;
  	mth&=msk_month;
  	FatTime|=BCD2Int(secs)>>1;
  	FatTime|=BCD2Int(mins)<<5;
  	FatTime|=BCD2Int(hrs)<<11;
  	FatTime|=BCD2Int(date)<<16;
  	FatTime|=BCD2Int(mth)<<21;
  	FatTime|=(BCD2Int(yr)+20)<<25;
  	return FatTime;
Thanks Thorsten,
it works fine.
The only thing I had to do was put in
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
around the function declarations in ff.h for c++ compilation.
It would be good (for c++ coders) if headers get committed this way.
Cheers
I don't want to change the original header files for such a purpose, because the modification would get lost if I (or somebody else) would update to a newer version, and the next guy who would try to compile your application would get confusing compile errors.
You could just wrap the #include statements in your .cpp file instead:
extern "C" {
#include <ff.h>
#include <diskio.h>
[/code]
This has the same effect.
