[Fixed] Hard Fault PC=0x0003199c
Marxon
Hi everyone,
there is a problem with my Midibox Sequencer V4 (LPC Core)
If i want to save a Track Event Preset, the sequencer stops working and shows the following error:
It creates a correct named preset but its empty (0 kb filesize)
But from time to time it saves it correctly.
I tried different sd-cards without success.
What couldt be the problem? I searched around the firmware files for this error code but it is not listed
and i dont really know how to debug it.
Thanks a lot for your help!
Marxon
Edited by Marxon
Of course!
Additionally these are my SD-Card infos from the Sequencer:
[41937.654] SD Card Informations
[41937.654] ====================
[41937.654] --------------------
[41937.654] CID:
[41937.654] - ManufacturerID:
[41937.654] - OEM AppliID:
[41937.654] - ProdName: SD01G
[41937.656] - ProdRev: 36
[41937.656] - ProdSN: 0x00e8039c
[41937.656] - Reserved1: 45
[41937.656] - ManufactDate: 107
[41937.656] - msd_CRC: 0x2c
[41937.656] - Reserved2: 1
[41937.656] --------------------
[41937.658] --------------------
[41937.658] - CSDStruct: 0
[41937.658] - SysSpecVersion: 0
[41937.658] - Reserved1: 0
[41937.658] - TAAC: 93
[41937.658] - NSAC: 0
[41937.658] - MaxBusClkFrec: 50
[41937.660] - CardComdClasses: 309
[41937.660] - RdBlockLen: 9
[41937.660] - PartBlockRead: 1
[41937.660] - WrBlockMisalign: 0
[41937.660] - RdBlockMisalign: 0
[41937.660] - DSRImpl: 0
[41937.660] - Reserved2: 0
[41937.662] - DeviceSize: 3883
[41937.662] - MaxRdCurrentVDDMin: 6
[41937.662] - MaxRdCurrentVDDMax: 6
[41937.662] - MaxWrCurrentVDDMin: 6
[41937.662] - MaxWrCurrentVDDMax: 6
[41937.662] - DeviceSizeMul: 7
[41937.664] - EraseGrSize: 16
[41937.664] - EraseGrMul: 13
[41937.664] - WrProtectGrSize: 31
[41937.664] - WrProtectGrEnable: 0
[41937.664] - ManDeflECC: 0
[41937.664] - WrSpeedFact: 5
[41937.664] - MaxWrBlockLen: 9
[41937.666] - WriteBlockPaPartial: 0
[41937.666] - Reserved3: 0
[41937.666] - ContentProtectAppli: 0
[41937.666] - FileFormatGrouop: 0
[41937.666] - CopyFlag: 0
[41937.666] - PermWrProtect: 0
[41937.668] - TempWrProtect: 0
[41937.668] - FileFormat: 0
[41937.668] - ECC: 0
[41937.668] - msd_CRC: 0x41
[41937.668] - Reserved4: 1
[41937.668] --------------------
[41937.668]
[41937.668] Reading Root Directory
[41937.670] ======================
[41937.670] Retrieving SD Card informations - please wait!
[41937.670] SD Card: '': 1008 of 1017 MB free
[41937.670] [.....d.] 08/06/08 01:12:50 AM <DIR> 0 SESSIONS
[41937.672] [.....d.] 08/06/08 00:48:32 AM <DIR> 0 SYSEX
[41937.672] [.......] 08/06/08 01:12:54 AM 2080 MBSEQ_BM.V4
[41937.672] [......a] 00/00/-20 00:00:00 AM 850 MBSEQ_GC.V4
[41937.674] [......a] 08/06/08 02:55:38 AM 16792 MBSEQ_HW.V4
[41937.674] [.......] 06/03/09 06:48:46 PM 692 NEUTEX~1.TXT
[41937.674] [.....d.] 02/25/12 01:42:48 PM <DIR> 0 MIDI
[41937.676] [.....d.] 08/06/08 00:26:58 AM <DIR> 0 PRESETS
[41937.676]
[41937.676] Checking SD Card at application layer
[41937.676] =====================================
[41937.676] Current session: /SESSIONS/MRX
[41937.678] File /SESSIONS/MRX/MBSEQ_B1.V4: valid (64 patterns)
[41937.678] File /SESSIONS/MRX/MBSEQ_B2.V4: valid (64 patterns)
[41937.678] File /SESSIONS/MRX/MBSEQ_B3.V4: valid (64 patterns)
[41937.680] File /SESSIONS/MRX/MBSEQ_B4.V4: valid (64 patterns)
[41937.680] File /SESSIONS/MRX/MBSEQ_M.V4: valid (128 mixer maps)
[41937.680] File /SESSIONS/MRX/MBSEQ_S.V4: valid (64 songs)
[41937.682] File /SESSIONS/MRX/MBSEQ_G.V4: valid
[41937.682] File /SESSIONS/MRX/MBSEQ_BM.V4: valid
[41937.682] File /SESSIONS/MRX/MBSEQ_C.V4: valid
[41937.682] File /MBSEQ_C.V4: valid
[41937.684] File /MBSEQ_BM.V4: valid
[41937.684] File /MBSEQ_HW.V4: valid
[41937.684] done.
[43374.819] [sEQ_UI_Button_Handler] Button SR:1, Pin:1 not mapped, it has been pressed.
[43374.819] [sEQ_UI_Button_Handler] Button SR:1, Pin:4 not mapped, it has been pressed.
[43374.915] [sEQ_UI_Button_Handler] Button SR:1, Pin:1 not mapped, it has been depressed.
[43374.915] [sEQ_UI_Button_Handler] Button SR:1, Pin:4 not mapped, it has been depressed.
[43385.667] Track Overview:
[43385.667] ===============
[43385.667] | Track | Mode | Layer P/T/I | Steps P/T | Length | Port | Chn. | Muted |
[43385.669] +-------+-------+-------------+-----------+--------+-------+------+-------+
[43385.670] | G1T1 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 1 | no |
[43385.670] | G1T2 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 2 | no |
[43385.672] | G1T3 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 3 | no |
[43385.673] | G1T4 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 4 | no |
[43385.674] | G2T1 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 13 | no |
[43385.674] | G2T2 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 14 | no |
[43385.676] | G2T3 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 15 | no |
[43385.677] | G2T4 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 16 | no |
[43385.678] | G3T1 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 13 | no |
[43385.678] | G3T2 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 14 | no |
[43385.678] | G3T3 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 15 | no |
[43385.680] | G3T4 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 16 | no |
[43385.680] | G4T1 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 13 | no |
[43385.682] | G4T2 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 14 | no |
[43385.682] | G4T3 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 15 | no |
[43385.684] | G4T4 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 16 | no |
[43385.684] +-------+-------+-------------+-----------+--------+-------+------+-------+
[43385.685] done.
Edited by Marxon
  • 2 months later...
I haven't changed anything to solve this issue, as I wasn't able to reproduce it.
Please let me know if it fails again on future MBSEQ firmware updates, it could be related to a memory allocation issue which causes memory accesses to invalid addresses (this will be hard to troubleshoot -> therefore "hard fault" ;-))
