tupinamba Posted July 14, 2012 Posted July 14, 2012 (edited) Hello, I noticed that I have a sync problem in song mode that doesn't exist when I play the pattern alone. My midi devices (x0xb0x, MB6582 and Jomox) are well synchronized when I play the pattern, but when I play it on Song Mode, they are not synchronized anymore! Or to be more precise : they are synchronized on the 1st pattern but the sync is slightly lost when switching to another pattern. I noticed this because I use a rhythm box (DR-5) to give my drummer a clic, and the clic is OK at the beginning but starts to unsync when switching to another pattern. Sometimes it even starts with difficulty, doubling the first note, and in this case the clic is unsynchronized. Any clue ?... Thanks! Edited July 14, 2012 by tupinamba
tupinamba Posted July 15, 2012 Author Posted July 15, 2012 I finally solved part of the issue : I noticed that I do not have a sync problem at the start of a song when I choose SONG MODE the click back on the PATTERN view before starting the song... This is kinda weird but this works...
TK. Posted July 15, 2012 Posted July 15, 2012 Very strange! Are you using your MBSEQ in Master or Slave mode? And could you please give my your "system" information after it happenes: 1) play the song until it gets out-of-sync with your MIDI gear 2) open MIOS Studio and connect to your MBSEQ 3) enter "system" in the MIOS Terminal 4) post the output here Best Regards, Thorsten.
pcbatterij Posted July 15, 2012 Posted July 15, 2012 tupinamba, I might have the same issue. when I play a song a hear a "hesitation" at the first step of the second pattern played. Tk: I'll check the requested info here after hearing the glitch. cheers, Jef
pcbatterij Posted July 15, 2012 Posted July 15, 2012 (edited) Tk, The output from MIOS terminal is: when in pause: [7935.547] system [7935.548] System Informations: [7935.549] ==================== [7935.549] MIDIbox SEQ V4.058 © 2012 T. Klose [7935.549] Operating System: MIOS32 [7935.549] Board: MBHP_CORE_LPC17 [7935.549] Chip Family: LPC17xx [7935.549] Serial Number: 609F1111AE0225351487CCC42000005F [7935.549] Flash Memory Size: 524288 bytes [7935.549] RAM Size: 65536 bytes [7935.549] Systime: 01:21:00 [7935.549] CPU Load: 59% [7935.549] MIDI Scheduler: Alloc 0/ 19 Drops: 0 [7935.549] Stopwatch: Overrun! [7935.550] Current Root Note (via Keyboard): C-3 [7935.550] done. when song stopped: [7967.539] system [7967.541] System Informations: [7967.541] ==================== [7967.541] MIDIbox SEQ V4.058 © 2012 T. Klose [7967.541] Operating System: MIOS32 [7967.541] Board: MBHP_CORE_LPC17 [7967.541] Chip Family: LPC17xx [7967.541] Serial Number: 609F1111AE0225351487CCC42000005F [7967.541] Flash Memory Size: 524288 bytes [7967.541] RAM Size: 65536 bytes [7967.542] Systime: 01:21:32 [7967.542] CPU Load: 55% [7967.542] MIDI Scheduler: Alloc 0/ 19 Drops: 0 [7967.542] Stopwatch: Overrun! [7967.542] Current Root Note (via Keyboard): C-3 [7967.542] done. when song playing: [8433.955] system [8433.956] System Informations: [8433.958] ==================== [8433.958] MIDIbox SEQ V4.058 © 2012 T. Klose [8433.958] Operating System: MIOS32 [8433.958] Board: MBHP_CORE_LPC17 [8433.958] Chip Family: LPC17xx [8433.958] Serial Number: 609F1111AE0225351487CCC42000005F [8433.958] Flash Memory Size: 524288 bytes [8433.958] RAM Size: 65536 bytes [8433.958] Systime: 01:29:18 [8433.958] CPU Load: 77% [8433.958] MIDI Scheduler: Alloc 0/ 19 Drops: 0 [8433.958] Stopwatch: Overrun! [8433.958] Current Root Note (via Keyboard): C-3 [8433.958] done. Edited July 15, 2012 by pcbatterij
pcbatterij Posted July 15, 2012 Posted July 15, 2012 Tk, It's set to Auto mode and I am using it as a master. cheers, Jef
tupinamba Posted July 17, 2012 Author Posted July 17, 2012 Hi Thorsten, hi Jef, I can't copy - paste the output I get... I'm using the Mac version of MIOS. Do you know if there's a way to do it ? Thanks !
pcbatterij Posted July 17, 2012 Posted July 17, 2012 Tupinamba, I'm using the MS Windows version where I can right click in the terminal windows and choose select all and then copy. Are you using a LPC17 core? Cheers, Jef
pcbatterij Posted July 19, 2012 Posted July 19, 2012 tupinamba, were you able to get the text from the MIOS terminal? cheers, Jef
TK. Posted July 22, 2012 Posted July 22, 2012 I can't reproduce this issue. E.g. I tried it together with a Yamaha RM1x, but both sequencers are always 100% in sync. Could you please attach your session in a .zip file? Best Regards, Thorsten.
pcbatterij Posted July 25, 2012 Posted July 25, 2012 Thorsten, I have upgraded the frimware of my mb909 cs and I don't have the "glitch" anymore. I have also played around in the session, so I am not sure wither it's the new firmware or if there was something wrong with the session. I will include the zipped session anyway, and below is an extract from s32 SEQ_SONG_FetchPos(u8 force_immediate_change) in the song.c file, because I have changed it (in my non-professional way) a bit for my "drum" version. (you'll also see why I asked the question about the mutes in song :-) ) I use the song screen in a different way than it was originally intended for. :blush: this is what I get now from the MIOS Studio: [183382.043] system [183382.044] System Informations: [183382.045] ==================== [183382.045] MIDIbox SEQ V4.059 © 2012 T. Klose [183382.045] Operating System: MIOS32 [183382.045] Board: MBHP_CORE_LPC17 [183382.045] Chip Family: LPC17xx [183382.046] Serial Number: 609F1111AE0225351487CCC42000005F [183382.046] Flash Memory Size: 524288 bytes [183382.046] RAM Size: 65536 bytes [183382.047] Systime: 00:01:45 [183382.047] CPU Load: 21% [183382.047] MIDI Scheduler: Alloc 0/ 19 Drops: 0 [183382.047] Stopwatch: 11/142 uS [183382.047] Current Root Note (via Keyboard): C-3 [183382.047] done. default: if( s->action >= SEQ_SONG_ACTION_Loop1 && s->action <= SEQ_SONG_ACTION_Loop16 ) { song_loop_ctr = 0; song_loop_ctr_max = s->action - SEQ_SONG_ACTION_Loop1; seq_pattern_t p; // TODO: implement prefetching until end of step! if( s->pattern_g1 < 0x80 ) { p.ALL = 0; p.pattern = s->pattern_g1; p.bank = s->bank_g1; seq_core_trk_muted = ~((1<< s->bank_g2) & 0x0f); SEQ_PATTERN_Change(0, p, force_immediate_change); } if( s->pattern_g2 < 0x80 ) { p.ALL = 0; p.pattern = s->pattern_g2; p.bank = s->bank_g2; SEQ_PATTERN_Change(1, p, force_immediate_change); } /* if( s->pattern_g3 < 0x80 ) { p.ALL = 0; p.pattern = s->pattern_g3; p.bank = s->bank_g3; SEQ_PATTERN_Change(2, p, force_immediate_change); } if( s->pattern_g4 < 0x80 ) { p.ALL = 0; p.pattern = s->pattern_g4; p.bank = s->bank_g4; SEQ_PATTERN_Change(3, p, force_immediate_change); } */ } } } while( again ); return 0; // no error }
sneakthief Posted July 25, 2012 Posted July 25, 2012 I have this same problem with my MB-808 in pattern mode (as slave). Should I start a new thread about it?To be specific, I'll send a pattern change command from my RS7000 via midi and the pattern on the 808 changes but the first beat is about 30-40ms too late.
TK. Posted July 25, 2012 Posted July 25, 2012 I think that all three issues don't belong together. @tupinamba: I need the copy&pasted system info (right-click in terminal window, copy, paste into the forum reply). In addition, I need your session directory. @pcbatterij: it isn't really helpful if you are reporting issues of a modified firmware in such a thread - I can't (and won't have the time) to analyze such an issue with your modifications, it could be related to something totally different, and since your only fragmentally inform me about your changes, it makes it even more difficult to understand the backgrounds - please open your own thread and just post your observations there, I will answer if I know an immediate answer, or if I can puzzle it from your descriptions. E.g. have you ever considered that the delays could be caused by the graphical LCD that you are using? @sneakthief: thats (unfortunately) a known limitation: loading a pattern from BankStick takes some time. It's usually done 2..3 MIDI ticks before the next step will be played, therefore you won't notice the delay in song/chain mode. But if you are requesting a pattern change from external, MB808 obviously can't predict your intention, therefore the delay can't be prevented. This is unrelated to the MBSEQV4 issue here, since a) in song mode the patterns are loaded some (micro)ticks before the change, in addition MBSEQV4 includes a clever preloading mechanism which should ensure 100% stable timings (therefore I really want to know, what could go wrong here)... and b) loading patterns from a SD Card is much faster compared to the BankStick Best Regards, Thorsten.
tupinamba Posted September 11, 2012 Author Posted September 11, 2012 (edited) Hi TK, I'm back working with my MBSEQ and so I'm trying to fix my SYNC issue. I'm having a hard time getting the SYSTEM output as with my macbook I cannot copy-paste the output from MIOS... I'll have to connect the MBSEQ to a PC. I just noticed something that could be a clue: When I start a pattern in "pattern mode", the BEAT led is perfectly synchronized to the 16 step leds... But with the very same pattern in "song mode", the 16 step led is late (this is very easy to check on step 9 as both leds are very close and I can see they aren't together anymore) The problem seems to occur when switching from one song position to the next (pattern change). I'm going to get the SYSTEM output very soon but this may be a start... Thanks again TK for developing such an amazing project and for being so reactive! Edited September 13, 2012 by tupinamba
tupinamba Posted September 12, 2012 Author Posted September 12, 2012 (edited) Hi Thorsten, Here are finally the results of the SYSTEM query : When stopped : [1433.777] system [1433.794] System Informations: [1433.804] ==================== [1433.814] MIDIbox SEQ V4.062 © 2012 T. Klose [1433.828] Operating System: MIOS32 [1433.839] Board: MBHP_CORE_STM32 [1433.850] Chip Family: STM32F10x [1433.860] Serial Number: 30FF5561314B343455361743 [1433.876] Flash Memory Size: 524288 bytes [1433.889] RAM Size: 67107840 bytes [1433.898] Systime: 00:06:17 [1433.905] CPU Load: 40% [1433.916] MIDI Scheduler: Alloc 0/ 11 Drops: 0 [1433.931] Stopwatch: 67/914 uS [1433.941] Current Root Note (via Keyboard): C-3 [1433.952] done. When playing and still synchronized : [1972.538] system [1972.556] System Informations: [1972.565] ==================== [1972.576] MIDIbox SEQ V4.062 © 2012 T. Klose [1972.590] Operating System: MIOS32 [1972.601] Board: MBHP_CORE_STM32 [1972.611] Chip Family: STM32F10x [1972.622] Serial Number: 30FF5561314B343455361743 [1972.637] Flash Memory Size: 524288 bytes [1972.650] RAM Size: 67107840 bytes [1972.659] Systime: 00:15:16 [1972.667] CPU Load: 51% [1972.677] MIDI Scheduler: Alloc 1/ 21 Drops: 0 [1972.692] Stopwatch: 250/953 uS [1972.702] Current Root Note (via Keyboard): C-3 [1972.713] done. or : [1984.824] system [1984.841] System Informations: [1984.852] ==================== [1984.861] MIDIbox SEQ V4.062 © 2012 T. Klose [1984.876] Operating System: MIOS32 [1984.887] Board: MBHP_CORE_STM32 [1984.897] Chip Family: STM32F10x [1984.908] Serial Number: 30FF5561314B343455361743 [1984.924] Flash Memory Size: 524288 bytes [1984.937] RAM Size: 67107840 bytes [1984.945] Systime: 00:15:28 [1984.953] CPU Load: 51% [1984.964] MIDI Scheduler: Alloc 1/ 21 Drops: 0 [1984.979] Stopwatch: 67/953 uS [1984.989] Current Root Note (via Keyboard): C-3 [1984.998] done. When playing but not synchronized anymore : [2084.187] system [2084.205] System Informations: [2084.214] ==================== [2084.225] MIDIbox SEQ V4.062 © 2012 T. Klose [2084.240] Operating System: MIOS32 [2084.251] Board: MBHP_CORE_STM32 [2084.261] Chip Family: STM32F10x [2084.271] Serial Number: 30FF5561314B343455361743 [2084.286] Flash Memory Size: 524288 bytes [2084.300] RAM Size: 67107840 bytes [2084.309] Systime: 00:17:07 [2084.317] CPU Load: 51% [2084.326] MIDI Scheduler: Alloc 2/ 21 Drops: 0 [2084.341] Stopwatch: 73/953 uS [2084.352] Current Root Note (via Keyboard): C-3 [2084.363] done. or : [2099.308] system [2099.325] System Informations: [2099.335] ==================== [2099.346] MIDIbox SEQ V4.062 © 2012 T. Klose [2099.361] Operating System: MIOS32 [2099.371] Board: MBHP_CORE_STM32 [2099.382] Chip Family: STM32F10x [2099.392] Serial Number: 30FF5561314B343455361743 [2099.407] Flash Memory Size: 524288 bytes [2099.420] RAM Size: 67107840 bytes [2099.429] Systime: 00:17:23 [2099.436] CPU Load: 51% [2099.447] MIDI Scheduler: Alloc 2/ 21 Drops: 0 [2099.462] Stopwatch: 140/953 uS [2099.473] Current Root Note (via Keyboard): C-3 [2099.483] done. With all those not synchronized results, the step leds are VERY obviously unsynchronized with the BEAT led... Edited September 13, 2012 by tupinamba
tupinamba Posted September 15, 2012 Author Posted September 15, 2012 (edited) I think that what happens is that when the SEQ switches from a pattern to the next one in SONG mode, it "swallows" a bit of the former pattern. I noticed it because the SEQ controls my s0xb0x which I programmed with notes that do not normally glide (they are all 90% in my pattern layout) but the last note of the pattern glides with the first note of the next pattern when changing pattern. And you can clearly hear that the first note of the next pattern comes too soon. And this doesn't happen when the pattern is looped (the very same last note of the pattern doesn't glide with the first note of the same pattern)! Weird, isn't it?... Edited September 15, 2012 by tupinamba
TK. Posted September 16, 2012 Posted September 16, 2012 Could also be related to the new guide track feature, I will check this. Best Regards, Thorsten.
tupinamba Posted September 17, 2012 Author Posted September 17, 2012 Actually I think that the problem is the RATOPC function : I disabled it and no more ends of patterns being swallowed when switching from a position to the next in "song mode"... Nevertheless, a "guide track" with its own indepedant measure will be a great improvement! Cheers, Gaël
TK. Posted September 17, 2012 Posted September 17, 2012 Thanks for the important detail! I don't use the RATOPC function by myself, and therefore assumed that the glitch was introduced with the latest enhancements for the guide track... The behaviour of RATOPC sounds faulty, I will check this as well. Best Regards, Thorsten.
tupinamba Posted September 18, 2012 Author Posted September 18, 2012 Great! I guess this is a progress... Cheers, Gaël
TK. Posted November 3, 2012 Posted November 3, 2012 The reported issues have been fixed in v4.063 Best Regards, Thorsten.
tupinamba Posted November 23, 2012 Author Posted November 23, 2012 That is great! Loads of thanks! All the best, Gaël.
