Sign in to follow this
Followers 0
docdune
Led Encoder Ring PCB
4 posts in this topic
It can be done but would require some coding on your side. However, it's a rather expensive and mechanically not perfect approach. Lots of small boards, and the LEDs quite far away from the front panel...
Share this post
Link to post
Share on other sites
I made the same question few months ago. Although I figure how to make my own LED ring PCB layout, never finished the layout on Eagle (Very lazy here because *finally* MIDI controllers are cheap in my place)
Just thinking if we can design a similar board that fits in a MIDIBox project. Some sort of breakout board for LED Ring + Enconders (further run a bulkorder or maybe smashtv or mike can start to sell it in the similar fashion of sparkfun´s breakout boards), anyone up to?
Share this post
Link to post
Mayhewlabs is way too expensive, It'd be cheaper to buy a Behringer BCR2000 and rip out the encoders + rings from that (plus you'd get a bunch of other components you could use)...
I would totally love a LED ring PCB. I'm about to wire a bunch of loose LED's into ~100 holes I've yet to drill. PITA. What I'm really interested in is LED ring + PWM interface, then you can use superbright LED's and use a single pot to adjust brightness on the fly. What I'm not sure about is using a ring with SMD LED's and how to mount that to a panel.
Share this post
Link to post
Followers 0
