ForestCat Posted September 13, 2012 Report Share Posted September 13, 2012 (edited) Hi, I built the DIY MIDI Merger: MIDI Merger Using the 16f88 variant. Burned the hex file w/ PicKit2, no errors other than a warning about some of the config options not being specified in the hex file. The merger works, i.e it receives data from both ports and echoes it at the output, except for the fact that it is dropping bytes, frequently, losing NoteOff, for example. This seems to be slightly worse on one input than the other. Does anyone have any ideas why this might be happening? Thanks. Edited September 13, 2012 by ForestCat Quote Link to comment Share on other sites More sharing options...
Janis1279 Posted September 14, 2012 Report Share Posted September 14, 2012 Hi, It's not the same: , but the additional resistor can do more stable the merger work. Regards, Janis Quote Link to comment Share on other sites More sharing options...
ForestCat Posted September 15, 2012 Author Report Share Posted September 15, 2012 Thanks, Janis. I'll try the resistor & see if it helps. Hi, It's not the same: , but the additional resistor can do more stable the merger work. Regards, Janis Quote Link to comment Share on other sites More sharing options...
OnOffArt Posted September 23, 2012 Report Share Posted September 23, 2012 Thanks, Janis. I'll try the resistor & see if it helps. Hi, I would also realize the merger with the 16F88 it works well with pullup resistor on pin 4 ? I don't want to use any leds I leave pins disconnected ? Peace Djé Quote Link to comment Share on other sites More sharing options...
nILS Posted September 24, 2012 Report Share Posted September 24, 2012 I don't want to use any leds I leave pins disconnected ? Yes. Quote Link to comment Share on other sites More sharing options...
OnOffArt Posted September 24, 2012 Report Share Posted September 24, 2012 Yes. Merci Quote Link to comment Share on other sites More sharing options...
