SwinSID nano & SID module - redundant components?
I was wondering which components on the SID module schematic might be redundant if you're building the module with SwinSID nano instead of 6581/8580. If I understand correctly, at least the 9/12VDC supply bundle is redundant, because SwinSID solely from 5VDC at J2.
What about filter caps C1 and C2? And if you know you're not going to use audio in, I guess you can leave out everything connected to SID pin 26 and connect it directly to ground?
Is this all?
