Labels, banks and conditions
sparx
Hello all
Been playing about with the NG project today, its great!
I'm driving a synth board which has two banks of sounds, first is General MIDI, so have set up an encoder to generate program change messages and display them on the LCD. All is fine.
Set up a toggle button and LED to switch to the other bank on (CC0=127), what is the best way to check the value of CC0 and display the correct voice?
Was thinking of something like an IFTHEN ELSE function but perhaps there is another way?
Thanks
S
Ok, understood.
Something like "conditional events" are not available yet. Please give me some time to think about a good solution which also covers other topics on the Agenda.
E.g. it would not only be nice to print labels depending on values of certain elements, but also to send different MIDI messages.
E.g. this would allow to send different CCs when an encoder is incremented/decremented. Or it would allow to realize a "split point" for a MIDI keyboard.
It could work somehow like demonstrated in this snippet:
/edit: final solution:
http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox_ng_v1%2Fcfg%2Ftests%2Fconev_5.ngc
But also:
/edit: final solution: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox_ng_v1%2Fcfg%2Ftests%2Fconev_4.ngc
I started with the conditional events.
You case is already working:
But the conceptional work isn't finished yet - there are some other cases I would like to cover as well, but which can't be handled by the current algorithm.
