Hawkeye Posted December 31, 2013 Report Posted December 31, 2013 A happy new year to all current and future TPD users :) That is is the great thing about open source and hardware, that initial ideas and hardware hacks can evolve, when people find them interesting. Ilmenator has done a great job and made a great PCB! Thanks! :flowers: Cheers and have a great time! :) Peter Quote
BlondGuy Posted January 3, 2014 Report Posted January 3, 2014 Hi I would LOVE to build the tpd, please put me down for this one if poss too. When get this going I will build a blm after that too. Quant. | forum name ----------------------- 2 | taximan 2 | JohnnieBee 1 | monokinetic 1 | Acul 1 | rvlt 2 | smidirin 1 | =FFW=> 1 | verpeiler (1 | jbdiver) (2 | gtxdude) (1 | chriss) (1 | mokomo) (1 | Marxon ) (1 | BlondGuy) Happy New Year guys, nice to see some beautifully constructed systems. Cheers Guy Quote
electrodancer Posted January 13, 2014 Report Posted January 13, 2014 (edited) please add me for a tpd Quant. | forum name ----------------------- 2 | taximan 2 | JohnnieBee 1 | monokinetic 1 | Acul 1 | rvlt 2 | smidirin 1 | =FFW=> 1 | verpeiler (1 | jbdiver) (2 | gtxdude) (1 | chriss) (1 | mokomo) (1 | Marxon ) (1 | BlondGuy) (1 I electrodancer) Edited January 13, 2014 by electrodancer Quote
ken Posted January 16, 2014 Report Posted January 16, 2014 Dear ilmenator. Please add me to the list. thx. Quant. | forum name ----------------------- 2 | taximan 2 | JohnnieBee 1 | monokinetic 1 | Acul 1 | rvlt 2 | smidirin 1 | =FFW=> 1 | verpeiler (1 | jbdiver) (2 | gtxdude) (1 | chriss) (1 | mokomo) (1 | Marxon ) (1 | BlondGuy) (1 I electrodancer) (2 I ken) Quote
Dangerz Posted January 18, 2014 Report Posted January 18, 2014 (edited) Hi ilme, you can add me for 2 boards ? Thx thx thx Davide Edited January 19, 2014 by Dangerz Quote
ilmenator Posted January 19, 2014 Author Report Posted January 19, 2014 Here is the updated list for the upcoming batch of TPD boards: 2 | gtxdude 1 | mokomo 1 | Marxon 1 | BlondGuy 1 | electrodancer 2 | ken 2 | Dangerz They should be here in about two weeks or so. Please adjust your "Notification Options" under "My Settings" such that you are notified (e.g. by email) when I send you a PM once the boards have arrived. Thanks guys! Quote
Marxon Posted January 19, 2014 Report Posted January 19, 2014 (edited) :D Edited January 19, 2014 by Marxon Quote
SMIDIRIN Posted January 23, 2014 Report Posted January 23, 2014 ilmenator or Hawkeye can you help me with the SR config, just built mine and have some signs its working but the only config on the wiki is for seq including 16x4 blm. I have wilba pcb + tpd only. Or have i missed the config somewhere else on ucapps? Thanks too for a great addition. Not too much stress with the smd, plenty of space compared to some i have worked on. Quote
Hawkeye Posted January 23, 2014 Report Posted January 23, 2014 (edited) Hi Smidirin, Great, that you´ve got it all soldered up, and i am glad, Ilmenator created that fine PCB and TK improved the code! This would be the relevant config section in the MBSEQ_V4.HW file - don´t change the 16x4 BLM section, but this one instead: ################################################## # Optional LED Track Position Display # See also http://www.midibox.org/dokuwiki/doku.php?id=tpd_pcb ################################################## # set to 1 or 2 to enable the relative track position display # 0: TPD disabled # 1: TPD enabled - columns are cathodes, rows are anodes # 2: TPD enabled - columns are anodes, rows are cathodes TPD_ENABLED 0 # define the DOUT shift register to which the columns are connected (0=disabled) TPD_COLUMNS_SR_L 0 # for a 16x16 TPD: define the SR to which the right columns are connected (0=disabled, use only 8x8 TPD) TPD_COLUMNS_SR_R 0 # define the DOUT shift register to which the green LED rows are connected (0=disabled) TPD_ROWS_SR_GREEN_L 0 # define the DOUT shift register to which the right green LED rows are connected (0=disabled, use only 8x8 TPD) TPD_ROWS_SR_GREEN_R 0 # define the DOUT shift register to which the red LED rows are connected (0=disabled) TPD_ROWS_SR_RED_L 0 # define the DOUT shift register to which the right red LED rows are connected (0=disabled, use only 8x8 TPD) TPD_ROWS_SR_RED_R 0 Also, have a look at the "optional bpm digits" and "optional step display" sections and modify those. The newest MBSEQ V4 hardware config file is available for download here: http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fsequencers%2Fmidibox_seq_v4%2Fhwcfg%2Fwilba%2F Edit: there seems to be a slight problem web downloading files with the given svn repository link above - never mind, you could just click on the file, mark its contents and copy&paste it to your favourite editor. Many greets, Peter Edited January 23, 2014 by Hawkeye Quote
ilmenator Posted January 23, 2014 Author Report Posted January 23, 2014 To make it easy, you could simply count down the shift registers on the BLM 16x4 that are not physically there in your setup. The BLM 16x4 uses 6 DOUT SRs and 2 DIN SRs. Starting from the config file in the Wiki (that includes the BLM 16x4 setup), in the part of the config file that Hawkeye is referencing above, reduce the number behind each TPD DOUT SR by 6, and behind each TPD DIN SR by 2. Also, make sure that you deactivate the BLM matrix, i.e. change ################################################## # Optional BLM Matrix ################################################## # set this value to 1 if each track has its own set of 16 LEDs to display unmuted steps and current sequencer position # or if you are using a button/led matrix for misc. button/LED functions BLM_ENABLED 1 to ################################################## # Optional BLM Matrix ################################################## # set this value to 1 if each track has its own set of 16 LEDs to display unmuted steps and current sequencer position # or if you are using a button/led matrix for misc. button/LED functions BLM_ENABLED 0 Once you have this up and running correctly, please send me your new config file and I'll add it to the Wiki for others! Quote
Teig1 Posted January 23, 2014 Report Posted January 23, 2014 Please add me for 1 board Brgds Ole Peder Quote
ilmenator Posted January 23, 2014 Author Report Posted January 23, 2014 Next batch of boards has arrived - everyone on the list should have received PM. Ole Peder, you're in for the next batch. Quant. | forum name ----------------------- 1 | Teig1 Quote
blingy Posted January 24, 2014 Report Posted January 24, 2014 Please add me to the next batch, didn't realize this was ongoing :D Thank you ilmenator Quote
ilmenator Posted January 24, 2014 Author Report Posted January 24, 2014 Quant. | forum name ----------------------- 1 | Teig1 1 | blingy Quote
Dangerz Posted January 28, 2014 Report Posted January 28, 2014 Mission accomplished :smile: pcb arrived!!! Thx Davide Quote
borfo Posted February 11, 2014 Report Posted February 11, 2014 I'll take a board on the next run too, please. Thanks. Quote
Elektruck Posted February 12, 2014 Report Posted February 12, 2014 (edited) I also want 2 of those boards, please. Thanx Edited February 12, 2014 by Elektruck Quote
ilmenator Posted February 12, 2014 Author Report Posted February 12, 2014 (edited) Quant. | forum name ----------------------- 1 | blingy 1 | borfo 2 | Elektruck Teig1 received a board from someone who backed out from the previous batch. Edited February 12, 2014 by ilmenator Quote
=FFW=> Posted February 13, 2014 Report Posted February 13, 2014 (edited) Quant. | forum name ----------------------- 1 | blingy 1 | borfo 2 | Elektruck 1 | =FFW=> Edited February 13, 2014 by =FFW=> Quote
ilmenator Posted February 21, 2014 Author Report Posted February 21, 2014 The third batch has arrived, there are spares available - if you want one board now let me know by PM or tell me in this thread! Quote
sebiiksbcs Posted March 3, 2014 Report Posted March 3, 2014 Hi Ilmenator, do you have 1 spare available for me? Thanks! Quote
ilmenator Posted March 3, 2014 Author Report Posted March 3, 2014 Yes - do you want a or just the board? Please PM me with your address so I can find out how much shipping is. Quote
borfo Posted August 25, 2014 Report Posted August 25, 2014 (edited) So, turns out the LED matrixes I ordered are too big - had to order more. In the meantime, I tried plugging my TPD module in without the LED matrixes. I set up the config file (the TPD is connected to my wilba frontpanel). The tempo encoder works, but the LED segment numbers don't seem to be working - two segments are lit on all the numbers, see the picture below. Could this be because the LED matrixes are not soldered on yet, or is this a symptom of a soldering problem? The 7-segment LED numbers are these ones: http://ca.mouser.com/ProductDetail/Kingbright/SC39-12GWA/?qs=JpELLRhtMc3ti3iuxtHgpw== I want to make sure I haven't screwed up any of the SMD soldering under the LED matrixes before I solder them on. Edited August 25, 2014 by borfo Quote
ilmenator Posted August 25, 2014 Author Report Posted August 25, 2014 I'm afraid this rather looks like a soldering problem on one or two of the pins on the ICs that are connected to the 7-segments. I am traveling until Friday evening so it is hard for me to diagnose remotely, but if you looked at the schematics in the Wiki you might see which are the pins at fault. Quote
