cuca Posted May 7, 2013 Report Share Posted May 7, 2013 Hello everybody. I have received today my sammichSID unit but im totally lost. Can somebody please answer my dubts / questions ? : 1 ) where can i get an instruction manual or something ? i have been searching in google but can´t find manual / pdf or something to start. 2 ) which software i need to import / export patches / sounds ? 3 ) which software i need to play SID files ? 4 ) where get the last firmware ? no more , for now is the only help i need . Very gratefull if somebody could help me . Thanks a lot . Im a noob . greetings all sid maniacs, -cuca , from Spain Quote Link to comment Share on other sites More sharing options...
jjonas Posted May 8, 2013 Report Share Posted May 8, 2013 (edited) 1 ) where can i get an instruction manual or something ? i have been searching in google but can´t find manual / pdf or something to start. Go to www.ucapps.de and check the panel on the left (scroll down), there's a Midibox SID v2 Synth section with a link to the User Manual. Start with the First steps section and go on from there. 2 ) which software i need to import / export patches / sounds ? I have used Rutger's Java-based editor, apparently it's not maintained anymore, but for me it works. There seems to be a newer editor available, but I haven't tried it (or them, if there's several). Check this link and under heading 'Alternative Editors': http://www.ucapps.de/midibox_sid_manual_ed.html 3 ) which software i need to play SID files ? This one I cannot answer. 4 ) where get the last firmware ? Go to ucapps.de and check the panel on the left. At the top there's a section called MIOS, click 'MIOS8 Download'. There, among other things, you will find the newest MBSID firmware (at present v2_043). Edited May 8, 2013 by jjonas Quote Link to comment Share on other sites More sharing options...
nILS Posted May 8, 2013 Report Share Posted May 8, 2013 3) ASID XP if you're on windows. Use the forum search if you're on some *nix or OSX. Generally. Use the forum search a bit more ;) A special google search suffixed with "site:midibox.org" is usually pretty helpful as well. Quote Link to comment Share on other sites More sharing options...
cuca Posted May 8, 2013 Author Report Share Posted May 8, 2013 Thanks for help. Today i got a soft called mios and it helps to import and export patches and more. I will get the asid this night and try to play sid music into the sammichSID. I have listened to all the 128 presets, some of you guys know where can i get more patches / sounds ? Thanks again Quote Link to comment Share on other sites More sharing options...
cuca Posted May 8, 2013 Author Report Share Posted May 8, 2013 hello i found the ASID player and it works with my sammichSID .But now i have a new question . how can i extract a sound from a SID tune and save it like a patch ? for example , i like the kick or the snare in a sid tune and i want to extract it and save it like a patch / sound. Do you know what i mean ? Need to do it in a DAW or something ? can i separate the channels in a SID tune with the sammichSID ? many questions , i don´t know how to do it . Can somebody helps me ? Quote Link to comment Share on other sites More sharing options...
nILS Posted May 8, 2013 Report Share Posted May 8, 2013 Please don't crosspost your questions all over the place. Quote Link to comment Share on other sites More sharing options...
cuca Posted May 10, 2013 Author Report Share Posted May 10, 2013 Hello. I would like to know if its possible to separate the sammichSID channels ( 1 to 6 for example) in a DAW , for example , channel 1 = bass , channel 2 = lead , channel 3 = kick , channel 4 snare , like a chiptune , like a sid track . Its possible to separate the channels ? How do it ? can somebody with experience tell me how do that for example in Ableton LIVE ? thanks Quote Link to comment Share on other sites More sharing options...
nILS Posted May 11, 2013 Report Share Posted May 11, 2013 Again. Please don't ask the same exact question in new threads. Quote Link to comment Share on other sites More sharing options...
cuca Posted May 11, 2013 Author Report Share Posted May 11, 2013 ok thanks Quote Link to comment Share on other sites More sharing options...
cuca Posted June 16, 2013 Author Report Share Posted June 16, 2013 I found solution to my problem because this forum is really DEAD . Now multitimbral is possible thanks to this Japan sammichSID user : http://tanikugu.blogspot.com.es/2013/05/how-to-multitimber-setting-for.html?showComment=1369491391377#c3670776101209793949 Quote Link to comment Share on other sites More sharing options...
nILS Posted June 16, 2013 Report Share Posted June 16, 2013 On behalf of all the people who make up this really dead forum: We're incredibly sorry for not supplying you with the support you so obviously deserve for a product which you either built yourself from designs that were worked on by numerous people over a bunch of years and given to you for free or which you bought pre-assembled - which means you didn't put any effort into anything at all. Since we so fatally failed in helping you, have a flower instead: :flowers: Quote Link to comment Share on other sites More sharing options...
ilmenator Posted June 16, 2013 Report Share Posted June 16, 2013 Glad someone finally woke us up from the dead :devil: :cheer: ! Quote Link to comment Share on other sites More sharing options...
SG888 Posted August 31, 2013 Report Share Posted August 31, 2013 Hmmm not dead but not sure if SARCASM is exactly noob friendly... Quote Link to comment Share on other sites More sharing options...
