lazerbeat Posted March 16, 2014 Report Share Posted March 16, 2014 I was wondering if it was possible to split 4 op instruments into 2 op instruments in ensemble mode? This would be kind of fun as I assume you could get up to 8 voices that way rather than 4 with 4op. I tend to like the fairly simple 2 op sounds so having a few more of them you play with would be fun! 4 x 2 op and 2 x 4op configurations would be fun too. Can it be done or would it need heavy re writing? Quote Link to comment Share on other sites More sharing options...
Sauraen Posted March 16, 2014 Report Share Posted March 16, 2014 Not in MIDIbox FM V1.4 / SammichFM, but yes in the upcoming The OPL3 itself has 6 4-op voices (that can be individually split into 2-op voices for a total of up to 12), plus 3 plain 2-op voices, plus 3 2-op voices that optionally become the 5-voice percussion system. The current versions of MIDIbox FM (V1.4 and SammichFM) have the 6 4-op voices permanently in that configuration, plus the percussion mode, and they never use those 3 extra 2-op voices. MIDIbox FM V2.0 allows you to configure all 18 2-op voices as you wish (within the limits of the chip). It's not a matter of rewiring, it would require a major overhaul in software of the synth engine, and I'm not sure the PIC microcontroller could handle it. Quote Link to comment Share on other sites More sharing options...
