phillwilson Posted March 21, 2014 Report Share Posted March 21, 2014 Hi again, I have spent another wonderful evening with my Midibox Seq v4 and I am starting to feel pretty at home with the front panel and its sequencing however, I seem to be having issue with realtime recording, it seems like certain notes played from my input keyboard are causing the sequencer to stop rather than recording the notes in realtime, I cant figure out why it would be doing this... the notes also seem to trigger some kind of switching between the layers ( I am figuring this form the 1,2,3 lights changing as certain notes are pressed)... any ideas what I have set up wrong? Quote Link to comment Share on other sites More sharing options...
Hawkeye Posted March 22, 2014 Report Share Posted March 22, 2014 Hola, sounds like unwanted MIDI remote in action to me :) You can disable it in your config file in MBSEQ_HW.V4 (right at the beginning). MIDI_REMOTE_KEY 0 And here is the MIDI remote documentation: http://ucapps.de/midibox_seq/mbseq_remote_functions.pdf Many greets and enjoy! Peter Quote Link to comment Share on other sites More sharing options...
phillwilson Posted March 22, 2014 Author Report Share Posted March 22, 2014 ah, that's IT for sure, is there any menu system on the actual midibox itself where this can be changed? I only ask because, to be honest , at the moment I am just a humble musician and have never dared to get involved with writing or fiddling with code...to my detriment I am sure, and if it has to be done so...I will look at it as acquiring some new skills, but thought it was worth an ask before I start looking at the "for dummies guides" thanks for taking the time, Phill Quote Link to comment Share on other sites More sharing options...
lukas412 Posted March 22, 2014 Report Share Posted March 22, 2014 As far as I know you can not change this from the panel, but don't worry. You don't need to compile or anything like that. If you remove your sd card and put it in a computer you will find a file in the root called MBSEQ_HW.V4 Right around line 14 you should see MIDI_REMOTE_KEY Make sure that is set to 0, put the sd card back in your seq and restart it if its still on. Enjoy, Luke Quote Link to comment Share on other sites More sharing options...
Hawkeye Posted March 22, 2014 Report Share Posted March 22, 2014 Correct! That just needs text file editing skillz, no problem, man! :-D Many greets and enjoy! Peter 1 Quote Link to comment Share on other sites More sharing options...
phillwilson Posted March 22, 2014 Author Report Share Posted March 22, 2014 Superb, can't wait to get home and have a play now. Thanks for your help Quote Link to comment Share on other sites More sharing options...
phillwilson Posted March 23, 2014 Author Report Share Posted March 23, 2014 Sorted thanks to all Quote Link to comment Share on other sites More sharing options...
