Make problem with latest Rev 2080 of MIOS32
robinfawell
SOLVED (I THINK)
Using Linux I was unable to download the MIOS32 Toolchain using the sudo wget command.  ( I still can't !)
However I downloaded the gcc-arm-none-eabi /etc / tar.bz2 file by clicking on the linux version on the midibox.org link.  Using Archive manager in Linux Mint I uncompressed the file.  Then I transferred to file to usr/local/ mios32_toolchain.  I added the latter directory.  This did not work either.  Then I realised that the path to the appropriate bin file was interrupted by the "gcc-arm-none-eabi-4_7-2013q3" diirectory.  This I removed.
After this I was able to compile and produce hex files.
I will raise a new post regarding the sudo wget command.
As mentioned previously I have damaged my core module and have decided to update to the STM Discovery.
My digital piano was revised last year and the program was based on TK's example of the fast scan matrix.  There a several changes due to the inclusion of the piano pedals and also an organ swell pedal for organ sounds.
I have made several changes to the app.c file on TK's original
The make file refers to an error
E:\Mios32\trunk\apps\examples\fastscan_button_matrix_16x16>make
rm -f project.hex
Creating object file for app.c
app.c:1:0: error: bad value (cortex-m4) for -mcpu= switch
make: *** [project_build/app.o] Error 1
I have looked in the project build file and see only references to the STM F10 processor not the STM Discovery processor.
project_build/app.o: app.c e:/mios32/trunk/include/mios32/mios32.h \
 e:/mios32/trunk/programming_models/traditional/stm32f10x_conf.h \
 e:/mios32/trunk/drivers/STM32F10x/v3.3.0/STM32F10x_StdPeriph_Driver/inc/stm32f10x_adc.h \
 e:/mios32/trunk/drivers/STM32F10x/v3.3.0/CMSIS/CM3/DeviceSupport/ST/STM32F10x/stm32f10x.h \
 e:/mios32/trunk/drivers/STM32F10x/v3.3.0/CMSIS/CM3/CoreSupport/core_cm3.h \
 e:/mios32/trunk/drivers/STM32F10x/v3.3.0/CMSIS/CM3/DeviceSupport/ST/STM32F10x/system_stm32f10x.h \
Is this the problem ?
Please help.
Robin
Later comment
I have tried the Tutorial 001 and again  "make" gives the same error.  I have checked and rechecked the environmental variables.
Edited by robinfawell
I have tried to compile using linux  rather than Win7.  I am very new to Linux this but am trying to learn.
It also fails but this time "make" shows a different  problem, it seems to have difficulties with the GCC_PREFIX.
I have tried = arm-none-eabi
                   = arm-none-eabi-gcc-4.7.4
                   = various date formats after the eabi
I am out of ideas.
Robin
Thanks Thorsten
I today have spent a fair amount of time today reading anything referring to STM32F4 and reread the README on the Tutorials. They,  as you confirm refer specifically to the STM32F4 core.  This is very reassuring to me as I would like to be able to use my digital piano again.
I mentioned earlier in my recent posts that I could not download the MIOS32_toolchain as described in Core Toolchain Setup.
I have tried many times using linux to use the following code
cd/usr/local
sudo get wget http;// www.org/mios32_toolchain/gcc-arm-none-xxxxxx.tar.bz2
sudo tar zxvf  gcc-arm-none-eabi-xxxxxx.tar.bz2
Each time I receive  Error 403
I have tried xxxxxx as 2013q3, 20130916, -4_7-2013q3-20130916-linux all with the same result. (error 403)
I am concerned that my ad hoc method to get the same result may have caused a corrupted hex file.
Your guidance will be much appreciated.
Robin
PS I believe have been using the correct toolchain  but perhaps not correctly.
TK
Yes It downloads OK.  It shows as follows.
Apache/2.2.23 (Unix) mod_ssl/2.2.23 OpenSSL/0.9.8e-fips-rhel5 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635 PHP/5.3.20 Server at www.midibox.org Port 80
Robin
Today's Comment.  I have used the linux link above to download the GCC file and constructed the Toolchain manually by creating a directory and transferring files into usr/local.  I believe that I have done this properly.
