VooDooSound Posted February 13, 2015 Report Posted February 13, 2015 I have 3 MF_NGs linked in a chain. And it already worked some time ago. MIOS Studio does not recognize MF_NG boards, while amidi -p hw:4,0,0 --dump shows incoming MIDI Events for fader movement on all MF_NGs on fader 1. I tried to connect just one MF_NG, but that did not work eather. The boards are not showing up in MIOS Studio, no matter what I do. What am I missing? Quote
TK. Posted February 15, 2015 Report Posted February 15, 2015 Either the wrong device ID is selected in MIOS Studio, or there is a problem with your Linux installation. Did you already work through the troubleshooting guide? http://www.ucapps.de/howto_debug_midi.html Which tests are working, which ones are failing? Best Regards, Thorsten. Quote
VooDooSound Posted February 17, 2015 Author Report Posted February 17, 2015 Hi, my MIDI output connector had been twisted... I can now connect to each MF_NG seperatly again. But in the chain, I have only access to the "Link Endpoint". Device Id 2 (MIDI Channel 3). Device Id 0 (MIDI Channel 1) and Device Id 1 (MIDI Channel 2) cannot be found, although they send and receive MIDI data. They are configured as "Link Forwarding Points". What am I still doing wrong? Quote
