martindunne1 Posted June 3, 2015 Report Share Posted June 3, 2015 hi there am trying to port GOOM to my stmdiscovery via mios and mios studio, i think i have mios installed but when i try to port project.hex i get nothing. the fist image is before i try to upload the hex file and image 2 is after. any help at all would be amazing. cheers mios.bmp after project upload.bmp Quote Link to comment Share on other sites More sharing options...
Shuriken Posted June 3, 2015 Report Share Posted June 3, 2015 (edited) Martin, The images you attached are unreadable. If you use jpg instead of bmp you can post much bigger images. Anyway, the steps should be: install bootloader: follow this tutorial then upload project hex through mios studio Edited June 3, 2015 by Shuriken Quote Link to comment Share on other sites More sharing options...
TK. Posted June 6, 2015 Report Share Posted June 6, 2015 It looks like the synth app is running. The goom synth has to be configured via CCs to output some audible sound. The other users might be able to help you on this, here the corresponding thread: Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
martindunne1 Posted June 17, 2015 Author Report Share Posted June 17, 2015 many thanks thorsten Quote Link to comment Share on other sites More sharing options...
martindunne1 Posted June 30, 2015 Author Report Share Posted June 30, 2015 hi thorsten am trying to delve into the goom source code to maybe add a few things. since all the code is now in c++ what compiler do you use? Quote Link to comment Share on other sites More sharing options...
Shuriken Posted June 30, 2015 Report Share Posted June 30, 2015 The toolchains are described on the wiki: http://www.midibox.org/dokuwiki/doku.php?id=application_development_32bit Quote Link to comment Share on other sites More sharing options...
martindunne1 Posted June 30, 2015 Author Report Share Posted June 30, 2015 many thanks Quote Link to comment Share on other sites More sharing options...
